How can brake hold be used to hill start 1st/reverse on the Si?
  1. MutatedMango
    MutatedMango Senior Member
    Mar 24, 2019
    228
    88
    Occupation:
    Student
    Philadelphia
    '19 Civic Si coupe
    New manual driver, was just wondering if there's any way to use the brake hold button to keep the clutch in and get the revs up to get off of a hill. Only thing is everywhere I'm reading is that it disengages when throttle is given so doesn't that make it useless essentially? Or is that only for the CVT civics? Would it just be better to get the revs up past 2k and then let the clutch out to the biting point then release parking brake?
    All advice appreciated thank you guys.
  2. fenix-silver
    fenix-silver Senior Member
    Nov 12, 2018
    399
    305
    Central PA
    2019 Si
    Brake hold is different than hill hold. Regardless of you having brake hold enabled, if you are on an incline at a stop w/ the clutch in, the car will engage the brakes until you release the clutch.
    edit: not sure if hill hold engages when in reverse
    MutatedMango thanked this.
  3. Tenshi
    Tenshi Senior Member
    May 8, 2018
    119
    86
    Phoenix
    2017 Honda Civic Si Coupe
    Break hold will work on a hill just fine. Try it without anyone behind you- it works as it should. It doesn't let go when you hit the gas, it lets go when the car will roll forward or about there.
  4. kibz
    kibz Member
    Apr 27, 2018
    Bay Area
    2019 Honda Civic Si
    For me, it disengages when the car starts moving forward. I've used it a few times on hills and it's never dropped back.
  5. dc2turbo
    dc2turbo Senior Member
    Jan 27, 2016
    2,918
    2,018
    usa
    civic,teg
    Brake hold goes by movement and not your clutch or gas pedal
  6. JT Si
    JT Si Senior Member
    Mar 17, 2019
    209
    142
    Willamette Valley
    JT
    2018 MSM Civic Si
    Can confirm the automatic hill hold works in reverse.
  7. fenix-silver
    Nov 12, 2018
    399
    305
    Central PA
    2019 Si
    From the owner's manual:
  8. fenix-silver
    Nov 12, 2018
    399
    305
    Central PA
    2019 Si
    Confirmed this morning that when stopped on a hill w/ the clutch in, the hill hold is engaged w/ my foot of the brake until I start releasing the clutch. And this is w/o the brake hold enabled.
  9. OP
    MutatedMango
    Mar 24, 2019
    228
    88
    Occupation:
    Student
    Philadelphia
    '19 Civic Si coupe
    Ohh OK I was under the impression it would disengage when given throttle. Brake hold sounds like a life saver for hill starts then?
  10. OP
    MutatedMango
    Mar 24, 2019
    228
    88
    Occupation:
    Student
    Philadelphia
    '19 Civic Si coupe
    Wait so on a hill the car doesn't roll back if the clutch is in? How come?
  11. OP
    MutatedMango
    Mar 24, 2019
    228
    88
    Occupation:
    Student
    Philadelphia
    '19 Civic Si coupe
    This is a life saver I'm going to use this on hill starts instead of the electric parking brake then. Thank you bro
  12. OP
    MutatedMango
    Mar 24, 2019
    228
    88
    Occupation:
    Student
    Philadelphia
    '19 Civic Si coupe
    That's awesome then. I was really worried about hill starts but brake hold makes them so much less intimidating.
  13. TheComebackKid
    TheComebackKid Senior Member
    Sep 22, 2017
    180
    104
    Montréal, Québec
    Nick
    2017 MSM Civic Si Sedan
    #13 TheComebackKid, Mar 26, 2019
    I remember my first manual car that did not have brake hold or hill assist!
    Brake hold will hold you there without your foot on the brake forever (well there may be a limit, 10 minutes I think and after that it automatically turns on the e-brake) and will disengage once you start moving forward.
    Hill assist holds you for a couple seconds when you take your foot off the brake, should be enough time to take off without the car rolling backwards.
  14. TheComebackKid
    Sep 22, 2017
    180
    104
    Montréal, Québec
    Nick
    Really?
    Usually hill assist holds you only for a couple of seconds not until you start moving.
    Nanook and MutatedMango thanked this.
  15. fenix-silver
    Nov 12, 2018
    399
    305
    Central PA
    2019 Si
    Guess I should clarify then. I didn't sit there too long w/ my foot off the brake. Just a couple seconds before giving it some gas and releasing the clutch. I'll check later to see how long hill hold stays engaged.
    MutatedMango and TheComebackKid thanked this.
