Hot Tire Pressures ?
JESFromASC
Anderson SC
2018 Type R, 2015 Silverado, 2007 Rabbit
265/35ZR-18 MICHELIN PILOT SPORT 4S XL
Where do I want to start for PSI for the track on a hot day in SC?
Where do I want to end up straight off the track on a hot day in SC?
Hit the paddock - take a reading - bleed off to ________ PSI.
Thanks
Browncoat3000
Red 5 standing by
Todd
Civic Si, Odyssey EX-L
Similar question, running stock all-seasons on the Si. This weekend I brought the fronts up to 42 hot, based on chalking, but had to drop the rears down to 29 hot before they even hinted at rolling. Anyone else have that issue?
JO3L
Joel
Southern California
FC1E5, NA6CE
I am having trouble understanding why everyone here recommends running such high tire pressures. All my fastest runs this year have been with tire pressures ranging from 30-35 psi hot.
I have tried running higher pressures around 37-40 psi square front to back and also a few times with more psi out back to help coax the car to rotate. Car never felt right to me and as soon as I drop the pressures the chassis feels more communicative and I experience far less understeer. Guess its time to get a tire pyrometer if i really want to get serious about things.
FYI these statements are made while running 245/45/17 Falken Azenis RT615K+ on 17x8 wheels.
JESFromASC
Anderson SC
Road Atlanta 2 weeks ago temperature range 48 to 58 pushing pretty hard started at 31 and found hot off the track to be 35 - 37 bled the 37 to 35 and ran hot 35 the rest of the time.
Tires were screaming in a few places but not lacking grip or getting slippery on me.
burglar
Matt
Troy, Mi
Civic
I think most of the higher recommendations in this forum are for the Rival S or re71r for autocross use.
JO3L
Joel
Southern California
FC1E5, NA6CE
Was that 35 psi hot square front to back?
This make sense now. I know the Falkens aren't the hottest tire out right now, but I got too good a deal on these not to give them a shot. Next season I am going to get a tire pyrometer to better set my pressures and not be guessing around so much.
JESFromASC
Anderson SC
I can't remember exactly but I think the biggest difference was about 3 pounds higher RF to LR.
I care about getting things to work well and I did check them multiple times but I don't keep a notebook or anything.
Not anywhere near as dramatic a difference as when the actual track surface temperature was 100+ in August at AMP a much more tight-twisty track.
