- Dec 9, 2017
- 9
- 345
- 187
- Frisco, TX
- 2018 Championship White Civic Type R
- Banned
- #61
No need to. I’ve already compared diagrams and part numbers from Honda.Also, the accord 2.0 block is aluminium with piston sleeves (CTR’s is iron) and yes different pistons. I believe they are specific to fuel efficiency.
The rods and crank are forged but not sure how different they are. I’ll try to find the honda release which states that.
Everything else sounds right.
the turbo is smaller, but you can slap the CTR turbo on it and Hondata has a tune for it.
you can also put the CTR lsd in the accord 2.0 turbo if you make sure to replace the oil pump gear with the CTR’s.
the engine will easily hold 300+ horsepower, and produces decent torque.
manuals can get a stage 3 tune
The 10 speed AT is stuck at stage 2
The R doesn’t have an iron block, the blocks are both aluminum and are the same part number. The Rs rods are forged however the crank is the same as the Accord again sharing the same part number. To my knowledge the oil pumps can’t be swapped because it’s a completely different setup due to the balancer shaft being integrated into the oil pump on the Accord. Tuning will also be different because the air temp sensors are in different locations. The Rs temp sensor is after the intercooler whereas it’s on the intake piping.
It’s not a simple ‘detuned’ R motor that everyone states. The Accord’s 2.0 will never be equal to the R motor no matter what’s done to it.
