RockyD
If I buy this could I flash other cars or is it specific to one vehicle? Thinking about buying it and charging around $200 to flash cars. Some people won't want to or can't spend $700.
No, it is locked to one vehicle.If I buy this could I flash other cars or is it specific to one vehicle? Thinking about buying it and charging around $200 to flash cars. Some people won't want to or can't spend $700.
If you could, how do you think Hondata would feel about that? SMH.If I buy this could I flash other cars or is it specific to one vehicle? Thinking about buying it and charging around $200 to flash cars. Some people won't want to or can't spend $700.
Does the hondata unit need to be plugged in at all times? Will it be resellable when I am done with the car?No, it is locked to one vehicle.
It doesn't need to stay plugged in but it's still locked to your VIN. To unlock it from your car you need to return to factory first.Does the hondata unit need to be plugged in at all times? Will it be resellable when I am done with the car?
Exactly, and once unlocked, you can use it in another car or sell it.It doesn't need to stay plugged in but it's still locked to your VIN. To unlock it from your car you need to return to factory first.
Can only flash one car, the Flash Pro locks to the VIN and ECU. Hondata has a dealer network and if you buy a dealer Flash Pro, then you can flash multiple vehicles. I Imagine the dealer FP is much more than $695.....If I buy this could I flash other cars or is it specific to one vehicle? Thinking about buying it and charging around $200 to flash cars. Some people won't want to or can't spend $700.
Lets clarify since he was asking questions, once unlocked from his civic, he can use it on another civic with the same type engine or sell it to someone with a the same civic engineExactly, and once unlocked, you can use it in another car or sell it.
Does anyone know where you would store that Hondata flashpro unit since it needs to be plugged in at all times? It looks kinda big to leave loose somewhere...Can only flash one car, the Flash Pro locks to the VIN and ECU. Hondata has a dealer network and if you buy a dealer Flash Pro, then you can flash multiple vehicles. I Imagine the dealer FP is much more than $695.....
Dude what??! Three people just said it DOES NOT need to be plugged it at all times. Only to flash and datalog. You should probably stay away from tuning if you can't even read.Does anyone know where you would store that Hondata flashpro unit since it needs to be plugged in at all times? It looks kinda big to leave loose somewhere...
There's no need to be rude about it. Remember that there was a point when all of us were new to the game.Dude what??! Three people just said it DOES NOT need to be plugged it at all times. Only to flash and datalog. You should probably stay away from tuning if you can't even read.
FTFYThere's no need to be rude about it. Remember that there was a point when all of us were new to the game.
@RockyD,
To reiterate for the fifth time, you only need to have the FlashPro plugged in to your OBD-II port when you are flashing a new map or datalogging. Otherwise, you don't need it plugged in at all (which means the majority of the time, especially after you are happy with the tune).
You didn't fix anything for me. "Iterate" is the appropriate term because to iterate means to do or say again. To "reiterate" would be to do again... again, which is redundant. Though "reiterate" is a common colloquial mistake, it is still just that, a mistake.FTFY
"So, you would use ‘reiterate’ only if you actually were iterating again, for a second/third time!"You didn't fix anything for me. "Iterate" is the appropriate term because to iterate means to do or say again. To "reiterate" would be to do again... again, which is redundant. Though "reiterate" is a common colloquial mistake, it is still just that, a mistake.
https://www.merriam-webster.com/dictionary/iterate
http://www.future-perfect.co.uk/grammar-tip/is-it-reiterate-or-iterate/
Cheers,
Zach
