PandaXpress
- Feb 19, 2016
- 17
- 433
- 202
- Los Angeles
- EX-T with Honda Sensing
Calipers have a different part number for the piston so I believe they are different. Brake pad set has a different part number too. I'm assuming the pad surface area is larger to benefit from the larger rotor diameter.
Don't forget you need to order the rotors too. 2x Rotors, 1 L caliper, 1 R Caliper, 1 Brake Pad set.
IMO, you are better off getting different brake compounds to change what you want to achieve with your brakes. The extra cost + extra unsprung weight may not be worth it unless you are seriously tracking but at that point, a big brake kit with multi-pistons and a floating caliper would be better. CTR upgrade?
i was thinking of doing the upgrade when i need to change my rotors and pads
