Hitting Sport Button While In WOT
Drew36
Drew
OH
2017 Honda Civic Si
I have a question, I have the TSP stage 1 on Ktuner. If I am under WOT and want a little more boost, does it hurt the car to hit the sport button while in WOT?
Seth_FC3
Seth
Miami
2020 SI coupe
If i'm not mistaken I don't think the car allows the sudden change in mode while WOT. Why not just have the car in sport to begin with?
DLEGAIR
Dexter
Pembroke Pines
2019 Honda Civic Si
Unless im mistaken sport mode doesn't affect boost just throttle response. unless you had someone tune your car to make more boost when pressing the sport button you should be fine.
Yonder
Miguel
San Diego
'18 Civic Si
Damn really? i could have sworn when im not in sport mode and i go WOT my max PSI is like 17. Where in sport its closer to 19 in the same gear.
Although i know for sure with ktuner, sport and comfort are two different tunes with two different max boosts.
Drew36
Drew36
Drew
OH
2017 Honda Civic Si
TSP Stage 1 gives more boost in sport mode.
Drew36
Drew36
Drew
OH
2017 Honda Civic Si
Well, sometimes I forget to put it in sport mode and I was just wondering if this was possible encase I ever wanted to race and the car next to me is slightly pulling on me, if I were to hit the sport button would it give me the additional 5lbs of boost I may need to get around them or not. Or would it hurt the car.
JT Si
Place
Car
If that's your plan, you absolutely have to put a NOS sticker on your sport button...
Seth_FC3
Seth
Miami
2020 SI coupe
I've thrown the car into sport while driving, not at WOT so I can't really give u an exact answer, but I know if ur going fast enough it won't let u switch over from comfort to sport
Drew36
Drew36
Drew
OH
2017 Honda Civic Si
Oh gotcha, makes since. Thanks!
JT Si
Place
Car
I've definitely turned off sport mode while I'm jamming through a tight corner faster than I should. It was a hair-raising experience having the dampers suddenly go mushy mid-turn.
I haven't attempted switching while under heavy throttle, though.
Seth_FC3
Seth
Miami
2020 SI coupe
Turning off will work, turning sport on while going fast enough won't work.. But I bet lol
EkSean
Sean
2019 PWP FC1
I’ve done it and I have tsp1 and it does work. I did it in 3rd and at about 4500rpm I hit sport and then vtec kicked in yo! You’ll feel a difference.
Drew36
Drew36
Drew
OH
2017 Honda Civic Si
Hmmm any idea if this will hurt the car? It would be rather nice having an additional 5lbs or so of boost on tap!
