Hit DC pothole today and got a small bubble on the side wall should I change tire immediately???
Launcher
Maryland
2018 Civic Hatchback (EX)
alright guys so I was heading to work today and was traveling at 25-35 mph on 295 in dc I hit a pothole (within the second I looked over my shoulder to switch lanes). Everything seemed fine and when I got to work I didn’t manage to see the bubble up until I got home and saw my tired was slightly flat . I checked the tire with soapy water and nothing is leaking .. as far as the small bubble should I be very concerned???
Honda Civic 10th gen Hit DC pothole today and got a small bubble on the side wall should I change tire immediately??? 5E6B5C66-30B4-4683-9143-1EEDB5A8EE35
Honda Civic 10th gen Hit DC pothole today and got a small bubble on the side wall should I change tire immediately??? E702B19F-BFD8-46F7-813E-3FE2C4FBF719
Honda Civic 10th gen Hit DC pothole today and got a small bubble on the side wall should I change tire immediately??? 68DA6003-F49D-4452-96C5-740350C7C67F
Honda Civic 10th gen Hit DC pothole today and got a small bubble on the side wall should I change tire immediately??? 03F3C998-31E5-4912-B3A0-6ED630A4CB81
Andre80
white civic
Europe
Civic X 1.5 sport +
yes, if put under stress it can explode and I advise you to change two tires
You broke the tire carcass ply
Honda Civic 10th gen Hit DC pothole today and got a small bubble on the side wall should I change tire immediately??? parts-of-a-tire-yokohama
ExVTEC
Elliot
2019 CTR
Agree with above. Also, if you must wait a few days move that tire to the back. You don't want a blow out up front.
Discount Tire
Arizona, USA
discountti.re
All Things Honda
Unfortunately what you're experiencing is what's called an impact break and the bubble you see is created from air escaping from a cut/crack in the tire's inner liner. Driving on a tire with an impact break is not recommended and as Andre80 noted, could fail under use.
Impact breaks are typically covered under road hazard so if you have this protection on your tires, you may want to check with the business the protection is under to see what they can do.
Launcher
Launcher
Maryland
Yea Im actually am going to try and see if this one tire shop down the street has the same tires in stock tomorrow. Luckily I have a second car I can use in the meantime.
Launcher
Launcher
Maryland
You’re def right about that I filled it up to the recommend psi and it escapes when driving it (no I didn’t take it in a big road)
Launcher
Launcher
Maryland
Hopefully I didn’t crack the rim since even if I fill it up to the recommended psi after a short drive around the neighborhood the air mostly escapes . And about that coverage I don’t think continental can do anything since this tires came oem with my car and I’ve had it for almost 2 years now . I checked their policy and it mostly seems they’ll cover it for a year sadly.
latole
Vaudreuil,Quebec ,Canada
I agree you need a new tire, maybe 2 if " too much" mileage.
No money for 2 , put rear tires in front wheels and the new tire at the rear wheels with the "older" front tire.
latole
If they don't have they can order and receive it ( them ?) in few days
Discount Tire
Arizona, USA
discountti.re
All Things Honda
Good point on the wheel and the shop should inspect it as it's possible there is damage on the inside portion of the wheel (and tire).
Circling back to the road hazard coverage, if you're under the Honda Care Warranty there may protection on the tires.
Launcher
Launcher
Maryland
Went to NTB and they said I have to order the tires and have them shipped to them since the ones I got oem are only online purchase ones . Also they said they would put be putting the new tires in the back etc .
Discount Tire
Arizona, USA
discountti.re
All Things Honda
We may be able to help - PM coming your way.
FC3L15B7
I'm a machine.
Daniel
www.youtube.com
2020 Honda Civic 2 Door Coupe Si / 1993 Chrysler Intrepid 3.5L
A bulge is a weak spot and it can cause the tire to fail. In my profession, it's a minor defect (needs to be replaced once returned to home terminal), so you can drive on it, but it needs to be changed. Cars on the street should follow the same ruleset, so if you need to wait a couple weeks until pay day, etc. don't sweat it, but get it done.
EDIT: "You’re def right about that I filled it up to the recommend psi and it escapes when driving it (no I didn’t take it in a big road)."
Right, well then, sweat. haha. :)
Launcher
Launcher
Maryland
I Actually didn’t drive my car for almost 4 days since I had to wait for my tires to ship. The same day I got em I went to a shop to get em changed . In the end they did a decent job minus a bit of a chip to the rim and a couple sockets had the paint literally like it seems sanded off . I guess the person that did it had the wrench spinning or something before even having the thing on the lugnuts. But other than that I can’t complain . It’s small imperfections they left that Won’t leave an eyesore on me .
Launcher
Launcher
Maryland
Thank you guys for trying to help me but since I’m barely on here I couldn’t get back to y’all. I did end Up paying and extra 16 dollars per tire from a different site which I could’ve saved by ordering from y’all
