Baime
- JP
- Jun 21, 2018
- 4
- 51
- 40
- Minnesota
- 2018 Civic Sedan EX-T
- Vehicle Showcase
I'm not proud about posting this, but if it helps someone on this forum, I would like that.
I live in Minnesota. We have had a brutal winter. Lots of cold weather, and record snow fall levels in February. They blast the roads with salt every time they plow. I've been having trouble getting my car into the car wash. You don't want to go when it is snowing, and you don't want to go if the temps are extremely cold. My car is Metallic Gray, and the lower half was white from layers of salt.
I finally got my car into a self serve car wash last week. I washed it all down, and then went over it with a soapy rag to get the salt layers off, and then a good rinse. I also sprayed my wheel wells out, washed down my floor mats, and wiped the inside edges of the doors, hood and trunk. I rinsed under the car on both sides to get some of the salt off of the underside of the car. It looked beautiful.
I started the car to pull it out of the car wash bay, and the engine rpms revved up very high, and started oscillating up and down.
All I could conclude is that I got some sensor connections got wet when I sprayed under the car.
I tried it multiple times, and the engine would again rev up to high rpms, and I couldn't get it out of park.
I finally got it to go into park, the engine started revving up again, and I put the trany into neutral to slow the car down, and then turned it off quickly again. I managed to get the car out of the wash bay, and then I called a tow truck. There was no way I was going to be able to drive it home or to a shop.
The next day the Honda dealer service guy called me, and said it was running perfect, and no codes were ever set.
This just didn't make much sense. If acted like a stuck throttle. He said the throttle is all electronical, and it would set a fault if there had been a problem.
When I went to get the car, it started fine, and I could put it in gear, but it was running too fast. At least 1500 rpm.
I gave it a little gas in neutral after I moved it, and it revved up to 2500 rpms, and didn't drop down. I knew it wasn't correct.
I went back in to talk with the service guy. He is trying to tell me it is normal, and he believes it is fine. He said I could leave it in the shop over night to warm up if I felt like that was necessary to thaw something out. He acted like I was being overly fussy about how my car ran. I considered it unsafe to drive. I was going on vacation for a week the next day. I decided to drive it home, and if it still was acting up when I returned, it was going back to the shop.
When I started driving down the road, if felt like my brake pedal was too low to the ground. I started to think it was stuck in the down position. I pulled into a parking lot to check it out.
Have you figured out the problem?
I had the damn Weathertech floor mat under the brake pedal, but over top of the throttle pedal. That was the problem all along. The computer was stopping me from engaging the transmission, because the rpms were too high.
I don't know who was more stupid, me, or the silly professional Honda tech telling me that it was behaving normally.
PS: I got charged for the tow. He told me if I would have called the Honda road side assistance number, it would have been free.
Take care, JP
FYI: My apologies about the title. It originally said "I'm a dumb ass", and I changed it. I obviously didn't delete the last part, and it won't let me edit the title.
Take care, JP
