High RPM when start up
Pilksdaniel
Daniel
Montreal
Civic Si HFP 2018
Hey Guys,
I´m not sure if it´s becasue its getting cold out (I live in Montreal its dipped below zero in the past few weeks overnight and the mornings are around 2 degrees celcius) or if its something to do with my car. I drive a 2018 Civic Si. Basically when I push start my car the RPM goes up to about 2000 and stays there for a while it only settles back to the normal spot when once ive driven for a while. It´s only off of coldstarts that I get this issue.
Thanks for the input,
-Daniel
repeet
Fort Mill, S.C.
jesus7feasts.fyi
'23 BRZ
Yeah, my car does that too. It seems to be how Honda handles the problems that a cold engine causes. I just let it sit until the engine RPMs drop to around 1200. Then I'm off.
Oil circulation is a big worry, but so is expansion and contraction. Especially with an aluminum engine. That's why I wait until the engine is warm enough for the computer to drop the RPMs.
Gotch
Rob
2022 Si
Mine just started doing this on and off as well (depending on how cold it is outside).
amirza786
A
Northern California
Hey Guys,
-Daniel
It's normal. I also have a Camry SE and Sienna (both V6's) and they do the same thing, so does my Si, and it does not get that cold here in California (this morning it was 55 degrees F). The idle goes down in a few minutes
racer
Dave
Virginia
2018 Civic Si sedan.
Yes its cold engine related. Its as much "engine" warm up as it is "exhaust warm up" to get the car emissions compliant (low) as quickly as possible. Most new cars have a high cold warm up.. up to 2,000rpm.. and slowly coming back down to traditional idle speed (700-900rpm)
GypsyR19
Nancy
NC
'17 Camaro SS, '18 6M-Civic Sport Hatchback
Every new vehicle we have (Civic, Camaro, Silverado) does same thing.
dblotii
David
NY
05 Si
It is the Catalyst heating Mode. Passing Federal emissions standards is all about getting the substrate inside the catalytic converter "lit-off" as soon as possible. The combination of high rpm and retarded spark timing can get the cat over 200C in less than 15 seconds
Dave
BIGBLUESI
New York
2018 Civic SI Coupe
Hey Guys,
-Daniel
Same here.That's why the oil is 0W20 the zero means it's thin when cold so you don't have thick oil at start up. Start up is when one of the most damaging times for the engine.
dblotii
David
NY
05 Si
Even the worst-designed engine gets pressurized oil to every bearing in the engine within 5 seconds of a cold-start. This is theoretically a concern, but for all practical purposes you don't have to worry about it; and you certainly do not have to wait more than 5 seconds from a cold-start to start driving. Just take it easy until the coolant gets up to temp.
Dave
RobXsi
Nope
Noneya
Nata
This couldve been alot shorter answers....
"Normal behavior" would be the answer...
If your engine didnt do that, id say you have a problem.
Ataricade
Midwest
2018 Civic Si
Hey Guys,
-Daniel
First car? That’s completely normal
