Asgroi9399
- Anthony
- Aug 16, 2017
- 4
- 41
- 13
- Monroe NJ
- 2017 Civic Sport
Hey everyone,
My name is Anthony and I am the proud owner of a 17 Sonic Gray Sport. I have had the car for a little over a year with 12k miles. After “break in” at about 1k miles I threw in a short ram intake and uploaded Hondatas +3 psi tune. After a couple thousand miles with this set up I tried out the 9 psi tune and noticed the stock clutch slipping under heavy load. So I began researching which clutch kit would be best for me considering I also wanted to upgrade the downpipe and exhaust and be able to hold the added power.
About a month ago I pulled the trigger on the fx300 and a replacement DMF and had it installed. I might also add I reflashed it back to stock for the clutch break in period. I must say I am very pleased with the over feel and drivability of the clutch kit. It is much smoother than I expected and I actually think it’s easier to use versus the stock clutch. I did the normal 500 miles of stop and go driving like my grandma was in the car not exceeding 4K Rpms or hitting peak boost. At 500 I installed the AFE catted downpipe while still on the stock tune.
I am now at 720 miles and figured I would get into a little spirited driving to see how this clutch holds. I do want to reach 1000 miles before fully letting loose. So here’s my question: I did both a 3rd and 4th gear pull from about 2500 to 4000 rpms WOT and noticed slight clutch slippage. When I let off the gas I would feel the clutch catch up with the engine. Any idea why this is happening? Is it any bit normal? Should I hold of on full throttle for another few hundred miles?
Keep in mind I have a SRI, 3” downpipe and catback... still not tuned and I am currently running stock boost levels. I am a little concerned and worried considering I did plenty of research and spent a nice chunk of change here. Please share any experience or tips. Thanks in advance
