Burgerstandman
- Aaron
- Jul 19, 2019
- 3
- 42
- 0
- Germany
- 2018 Honda Civic SI
@DerekRobinson
If it was a +14 I'd agree
It holds pressure still gets up to 25-26 psiCheck for boost leaks. You could have a loose hose
It really only gets that way when I’m in boost. Does -14 mean rich or lean?Check for boost leaks. You could have a loose hose
Funny but not helpful still laughing though
Negative numbers mean running rich.It really only gets that way when I’m in boost. Does -14 mean rich or lean?
So my drive wasn’t very long like maybe 10min or so and it seamed to only get there on the Long Term Fuel Trim for a good 1/4 mile after I did a little pull and let off. Usually during normal driving my LTFT stays right at -10I'm guessing you mean short term fuel trim then. Negative numbers mean running rich.
That's all it was meant to do...Funny but not helpful still laughing though
I’ll try and upload a data log in a while so you can see what I mean. STFT does swing wildly but will level out at around -8 to -10 but then I’ll do a little pull in second gear and during the pull it gets down to -4 or -6. The scary part is right when I let off and drive normal after that I’ll get LTFT -14 to -18 for a good few seconds before it levels back out. I appreciate the feedback your giving me. I’ll go double check hoses and everything in a bit and then do a data log. Also I’ll make sure to drive longer to get an accurate LTFTSTFT is real time. LTFT is kinda like an average. For STFT, If your running super negative or super positive while In boost something's off.
While regular driving STFT will swing wildly in both directions sometimes, this is normal.
Do you know if I can do that with the TSP stage 1 Tune? Also I’m a noob so how would I do that? Any tips?Tune your AFM!
Letting off and seeing it go rich is normal. -4 to -6 isn't that bad, anything 10 or over and I start to worry. Sounds like you need a tune for that intake. I'd still check for boost leaks l, just to be safeI’ll try and upload a data log in a while so you can see what I mean. STFT does swing wildly but will level out at around -8 to -10 but then I’ll do a little pull in second gear and during the pull it gets down to -4 or -6. The scary part is right when I let off and drive normal after that I’ll get LTFT -14 to -18 for a good few seconds before it levels back out. I appreciate the feedback your giving me. I’ll go double check hoses and everything in a bit and then do a data log. Also I’ll make sure to drive longer to get an accurate LTFT
