Lots of boost, lots of meth and all the supporting mods@TheSnotRocket Your CTS-V is 1000hp? What kinda mods does it have?
You lucky dog! That is on my list to get out there for a track day in Monterrey some day......what an American icon that track is.....My current definition of Heaven On Earth is swooping down into the Cork Screw at Laguna Seca in a Honda Civic Type R.
What's yours?
How is the reliability? I'd be worried my car would break down at any given time.Lots of boost, lots of meth and all the supporting mods
I built the car to be focused on road racing. Generally speaking, it's been rock solid with only a few issues here and there. Diff cooler was an absolute must and so was the meth (for cooling). It has a serious amount of cooling up front to help with the heat generated from the blower and the engine itself. The car has an extremely conservative tune in it as well so that it's not running on the edge. It's for sure a wild ride.How is the reliability? I'd be worried my car would break down at any given time.
Man, you shouldn't do meth while driving.Lots of boost, lots of meth and all the supporting mods
Do you find it difficult to use all that extra power? I'll be trading in my Si w/KTuner for an R in the Spring, and I'm debating whether it's worth it to unlock the R ECU. +30% more power doesn't seem so appealing if I can't ever use more than 60% of the throttle.I built the car to be focused on road racing. Generally speaking, it's been rock solid with only a few issues here and there. Diff cooler was an absolute must and so was the meth (for cooling). It has a serious amount of cooling up front to help with the heat generated from the blower and the engine itself. The car has an extremely conservative tune in it as well so that it's not running on the edge. It's for sure a wild ride.
Meh... I buy it by the drum full... it's the only wayMan, you shouldn't do meth while driving.
It's all about your level of expertise and how much you can get out of the car. At the end of the day, you learn what you have and learn what to expect out of a certain situation. Lets say you know how to handle a 100hp car. You learn how the car pushes in a corner and when you can get on the gas coming out of a corner. Well, a 200HP car, 500HP car, etc are all not much different.. it's just when you can do things, like getting on the gas out of the corner and how hard and quickly you can push the gas. If you, for example, are having wheel spin issues coming out of a corner in 1st and 2nd, just train yourself to not push the gas further than the car or tires will allow. You'll get into 3rd and realize that you can push the gas even more, or all the way and you'll possibly have more speed into the next brake zone. Better tires also help (to a point - there is no substitute for proper seat time and proper car control, even on crap tires or slick tracks) .Do you find it difficult to use all that extra power? I'll be trading in my Si w/KTuner for an R in the Spring, and I'm debating whether it's worth it to unlock the R ECU. +30% more power doesn't seem so appealing if I can't ever use more than 60% of the throttle.
Just means he was a n00b driver with red mist and should probably have and instructor in the car with him.Bonus: Challenger was following me and didn't realize my braking lines were not the same as his. He spun out in turn 3.
