Hatchback Stiffer Springs - Stock Height Options?
SpikedLemon
Spiked
Several
I've a 2019 LX Hatch and want a slightly stiffer ride (but really don't want to fork over for struts/shocks if it can be avoided).
Are there options to maintain a stock (or stock-ish) ride height with some slightly stiffer springs on a Hatch?
I've already bottomed out the air dam a couple times now (at stock height) on some steep driveways and learnt my lesson on how much worse it can get as a daily-drive with a former car that I dropped >2".
I've read elsewhere the Si springs are a higher spring rate but contribute to, roughly, a 0.7" drop. I assume I can keep the stock struts/shocks with this option.
Are there other options without significant drop?
hobby-man
GTA
Si springs will probably give you the most mild drop. Next option might be Megan Racing springs. Those are ~25mm / 0.9".
Yeet-n-Duner
j0
Tx
hb ex
well... not just spring..
BUT! you can always buy a full coilover set... and set it to factory height.
(as long you dont choose extreme low option)
if the coilover set has adjustable damper... you're more than golden.
there are a few selections out there.
i.e. bc racing, d2 racing, buddy club.... may be other companies by now.
nrchaytor
Nigel
NL
2017 Honda Civic Hatchback 6M
I just ordered a set of Si springs for my LX Hatch for the same reason.. wanted a slightly stiffer/sportier ride with minimal drop in ride height.. I will measure the actual drop in ride height when I get the Si springs installed.
piterek
Peter
Ontario, Canada
2019 Civic Hatch Sport Touring, 2010 Subaru Forester, 2015 Yamaha FJ-09
I just ordered a set of Si springs for my LX Hatch....
Will be doing the same to my 2019 Hatch Sport Touring, and will also install the Si rear stabilizer... and maybe a strut brace in the front. I think this combination will improve things enough and prep the car a bit for FP, when it becomes available for my ECU. Had my 2011 Civic fitted with HFP suspension, Si front and rear bars, and shifter bushings... miss that ride.
Where did you order the hardware?
nrchaytor
Nigel
NL
I got mine at https://www.hondaautopartswarehouse.com/
piterek
Peter
Ontario, Canada
Have you gotten around to doing this yet? Can you confirm you've ordered the springs for the sedan Si (per below)? Cheers.
Front spring L
51406-TBF-A01
Front spring R
51401-TBF-A01
Rear spring
52441-TBF-A01 (x2)
I am also after the stabilizer, part no. 52300-TBJ-A01.
Just found your other post (after install)... did someone botch the installation or were the parts incorrect? Feedback would be helpful. Thanks.
Bullet_127
Arturo
PR
2017 Civic EX-T Sedan
Sorry to hi-jack the thread, but could someone post the stock height for a 2017 ex-T sedan? I feel mine looks a little lower than others I see around...maybe its just me :confused:
aauty
Vancouver
2017 civic hatchback sport cvt
Finally got around to upgrading my 2019 Hatch ST to Si springs and Si rear stabilizer. Not a bad job if you've got the tools and an extra pair of hands here and there. The ride is nice and firm, with a much improved turn-in. Very happy with the upgrade. Not quite what I had on my 8th generation sedan (HFP suspension and Si stabilizers F+R), but a great improvement none the less, and all for well under $300 CAD. Drop is ~10-15mm, but that wasn't really important to me. Will be looking to tune next. Maybe a strut-brace, shifter bushings and a short-shift adapter before that.
Hi, your ride is looking good there. I’m also interested in doing Si springs for my hatchback too. Did you use the stock shocks? They will be okay with the Si’s stiffer spring rate?
piterek
Peter
Ontario, Canada
I suppose that will depend on the type of driving you plan on doing, but the car is very well behaved in street driving that I do. I don't throw the car hard around corners and I am not really looking to find limits... but this upgrade makes the car feel more sporty, and it works for me. I do recommend upgrading the stabilized while in there. It will add about half an hour to the project and it will complement the rest of the upgrade. I went with the Si bar and the overall combo is nicely balanced IMO.
aauty
Vancouver
I have been and do plan on tracking my civic occasionally(maybe once or twice a year). I do want to have a stiffer ride but don’t want to go the coilovers route so I thought the Si springs would be a good option. Since you only do street driving, I guess that won’t affect the stock shocks too much? Probably a different story if I’m going to track the car. Btw..I do the have an Si rear sway bar installed on mine and it’s a good upgrade.
jayy_swish
Jay
I went with a whiteline sway bar and I don’t regret it. Also look into the civic type r front subframe brace it’s a $30 mod that improves the handling up front. The front sway bar from the civic type R fits the hatchback models as well, but the whole subframe needs to be dropped in order to replace. Bought it from:
https://www.hondapartshq.com/
Brace: 50290-TGN-E00
2 bolts you will need: 90182-S2H-000
piterek
Peter
Ontario, Canada
Huh... never considered the brace. Conversion is now complete with the Si bar and the springs... but the subframe and the strut brace looks low effort enough to try. The rear engine mount looks stupid simple too. The car is nicely balanced for the street and much improved from stock, but clearly there's opportunity for more.
piterek
Peter
Ontario, Canada
Not necessarily... streets are punishing in their own way, and the dampers work hard. Track obviously offers other challenges. This mod helps reduce body roll, F-R is balanced and the car stays pretty square in sweepers. Have fun with whatever you decide.
highroller
U Hash
Pak / NY
Civic 1.5 Turbo
Hey guys I was thinking of going with Eibach Pro kit as I a slight drop.
Keeping that in mind two options popped up.
1. Megan Racing Lowering Springs ( Lowers: 1.0" Front, 1.0" Rear. Spring Rates: 162 lbs/in Front, 190 lbs/in Rear ). Drop is same as pro-kit but price is far better.
2. Si Stock Springs.
Which one would be better fit? I own touring version.
