hatchback 1.5 headers
  1. partialprint
    partialprint Senior Member
    Jan 4, 2017
    120
    Occupation:
    Graphic Designer / Musician
    BROWARD
    2017 Civic Hatch Sport
    It was brought to my attention recently that the 1.5 turbo on the hatch has headers as part of the engine, meaning they cannot be changed. Is this true ? IDK if buddy was right or what but that sounds strange.
  2. 360glitch
    360glitch Moderator
    3,844
    3,700
    2017 Civic Si Sedan
    Essentially there is no header. The cylinder head itself is designed to be the manifold the turbo bolts onto.
    Xyrex, partialprint and Sgtstaadanko thanked this.
  3. Sgtstaadanko
    Sgtstaadanko Senior Member
    May 5, 2016
    565
    400
    Earth
    2016 Civic EX-T
    Your buddy is right, @360glitch beat me to it.
    360glitch thanked this.
  4. OP
    partialprint
    Jan 4, 2017
    120
    Occupation:
    BROWARD
    so how can we get some real hp gains, the throttle body spacer is pointless, a loud exhaust is stupid and an overpriced cold air intake won't give any real gains especially in the hot heat of florida lol
    there are no parts out yet for these its annoying
  5. OP
    partialprint
    Jan 4, 2017
    120
    Occupation:
    BROWARD
    and is there a diagram showing how the manifold works how did you guys hear about this ?
  6. Newflyer3
    Newflyer3 Senior Member
    Oct 7, 2015
    1,743
    1,031
    Calgary, AB
    You get a tune for it like Hondata that uses existing hardware to increase horsepower. That's the beauty of turbocharged engines. With that said, it's 2017 and gone are the days where bolt ons were available left right a center.
    You should also consider that this is a brand new engine and that if you're used to K series or B series, those motors were out at least 5 years before there was a comprehensive list of extra hardware.
    FK7_, UberCivic and 360glitch thanked this.
  7. exyia
    exyia Senior Member
    Feb 10, 2017
    295
    326
    Houston
    2017 SportTouring Hatch, 2010 EvoX SE
    You will run into turbo limitations and then rod limitations long before the "header" becomes a restriction. This isn't an NA motor anymore you're playing with - if you want more airflow, just increase boost. Unless the head is restricting flow, there's no reason to upgrade it on a turbocharged car. Increasing un-restrictive volume is hardly going to improve anything worth the cost
  8. OP
    partialprint
    Jan 4, 2017
    120
    Occupation:
    BROWARD
    true the flash is like 650
    which you will need high performance tires for and will cost more money may also void your warranty after messing with the computer
    what about intercooler since I'm in hot florida will that help at all with performance ?
  9. Zerkom122
    Zerkom122 Senior Member
    Feb 2, 2017
    77
    Ktuner V1 is available for $450 I just placed an order for one.
    SilverGhost and partialprint thanked this.
  10. OP
    partialprint
    Jan 4, 2017
    120
    Occupation:
    BROWARD
    let me know your process/results and if you need new tires etc. your not scared about your drivetrain warranty ?
  11. Zerkom122
    Feb 2, 2017
    77
    Well I just flashed stage 2 and haven't been able to datalog yet as my laptop died right after flashing. According to my butt Dyno it's a huge improvement. Im not worried about the warranty as I can flash it back to stock and if they ask why it's been reflashed I'll say I had to change the battery. At least with just the flash you can go back to stock for service in 5 minutes vs headers which would require you to take them off and put the stock ones back on if they had them for this car.
  12. kshawn
    kshawn Senior Member
    Apr 23, 2016
    1,759
    1,292
    Occupation:
    Desktop Support Specialist
    Maine
    Matthew
    2017 Civic SI
    turbo is the limitation on ours. and can be maxed with a tune.
  13. Shankmeyster
    Shankmeyster Senior Member
    Mar 15, 2017
    2,793
    1,291
    AZ
    2020 Civic Sport Hatch
    You do understand that they can send the ECU out to the factory if they so desire and they can tell it's actually been reflashed?
  14. OP
    partialprint
    Jan 4, 2017
    120
    Occupation:
    BROWARD
    so tune is pretty much the only thing worth doing any gains for this car? but it is risky considering the warranty.
    i feel throttle body spacer, intake, and exhaust would be a waste of money with no real improvement
    then again this is my daily I just want wheels LOL the stock exhaust actually sounds pretty good I love it
    Would a high performance intercooler do anything performance wise ? sounds like a dumb question but
  15. Zerkom122
    Feb 2, 2017
    77
    Yeah they could but something catastrophic would have to happen and I'm willing to take that risk
