rajahdat
- Nov 30, 2017
- 11
- 87
- 85
- SouthWest
- 99 nevermind
So I got the CTR and decided to do all my "mods" at once. There has been talk about upgrading the rear engine mount and I went with Hasport as they are a local company. Street 62A version
My intial experience is you will notice NVH at low speeds, but this is expected. Give it a few hundred miles and it should break in and allow some movement.
Installation is easy if you have a lift. Basic hand tools is needed and patience. Remove the lower aluminum panel along with taking some of the plastic push pins of the rear plastic lower panel to allow flexing on removing the rear bolt. You don't have to take off the downpipe as the front bolt has a slot for you to "wiggle" it out. Prior to installtion of the new hasport mount lube up the bushing where it will contact the subframe in the rear. A bit force is needed to get the mount into place, I used a rubber mallet.
I'll post a follow up quick take after 500miles to see if the NVH came down or its still the same
