Link?Has anyone used Vis Carbon fiber hood wanted pictures top and bottom curious if its worth the extra $400 with leak proof vents
I haven’t had one in 10 years, but the clearcoat on ViS use to be horrible quality resulting in peel. I’m not sure if their clearcoat has improved since then, but depending on price it may be worth the risk.I had ViS, Seibon, and even ASM hood. I think the vis hood good for the money and I didn’t run hood pins. I would see it shake a little bit at higher speed. I was reading if you run the rain guard it negates the cooling effect, but it you just want the look then I guess it doesn’t matter.
