Has anyone cleaned there engine bay?
Alex_hockey69
Alex
Montreal
2017 civic si
Any advice on what the best way to clean your engine. What to cover. What parts are ok to get wet...
Darky
Darcy
SW Ontario
2017 Civic SI Coupe
I've hit mine several times with hot water pressure washer with no issues . Dont blast things up close where electrical connectors live or you might force water into them and be careful around the fuse box and ecu area. avoid hitting a hot engine If you use a cold water pressure washer.
I've used this method for 2 and a half years on my si. Engine bay looks brand new still
Dan9908
PA
19 Accord Sport 2.0/A10, 05 Civic LX
A damp rag works fine. No pressure washer, ever
Scott_ATL
Scott
Atlanta, GA, USA
2018 Civic HB Sport Touring, 2012 Ford Fusion Hybrid
From page 621 of the HB owner's manual:
• Do not spray high pressure water directly into the engine compartment. Instead,
use low pressure water and a mild detergent.
86salmon
It's Hedley, Hedley Lamarr!
Chucktown, SC
I dust with detailing brushes and wipe with a damp microfiber
SDAlexander8
Steve
Indianapolis, IN
Have you seen any bolts start to rust from doing this?
Neps18Si
P-Low
Davie, FL
2018 Civic Si sedan (sold), 2019 Civic Sport Hatch CVT
I hit mine up with a high pressure air hose and wipe the rest. I do it 2-3 times a month stays clean.
86salmon
Chucktown, SC
ClemsonPatriot
Kyle
South Carolina
2017 Honda Civic Si Sedan
I keep mine clean with a variety of either dry or damp microfiber towels, air hose, and a shop vac. I find it you're proactive with cleaning it, it truly never needs an actual wash from a hose.
das borgen
Richard
Columbus, Ohio
E36 M3, Ducati 748, '17 EGP Si Coupe
I did that actually for the 1st time last week. I used a hose, no pressure washer, to knock off loose grime, then I sprayed on some all purpose cleaner (Simple Green, diluted to 50/50 by volume), and then I used a brushed, and I finally sprayed water again to rinse.
I stuffed the intake box with plastic bags just to be sure I woulnd't get water in there by accident
