Hands on with TSP's Stage 1 tune for the 1.5T (non-Si)
turbo lover
Civic Hatchback Sport Touring
That sounds good to me. I didn't want too much clutch roasting torque down low and in the midrange, but always felt that the KTuner tune had room for improvement above 5000 rpm.
Myx
Delaware
I want to mention something that may be relatively minor or major, depending on how you look at it. This goes for the Ktuner Starter Stage 2 as well as the TSP Stage 1.
Those of you who do not have an aftermarket intercooler may consider getting one. The stock turbo is working its arse off with both of these tunes. It's running harder with more psi of boost and generating more heat. A lot of heat. An aftermarket intercooler will help minimize the effect of heat being generated by the stock turbo. I'm not the type of guy that usually say things like this but I've seen the difference an aftermarket intercooler has made.
Ktuner Stage 2 Map --> Best of 100.64mph in the 1/4 mile (Outside temps were in the 35f-45f range when running 98-99mph trap speeds typically).
Ktuner Stage 2 Map with Depo Racing Intercooler --> 102.4mph - 102.9mph trap speeds in 60f-65f weather.
TSP Stage 1 Beta with Depo Racing Intercooler --> 103.2mph - 104.7mph 60f - 70f weather
To get that topend you are looking for may just be an intercooler upgrade away. I'm convinced! Was curious to what I'd run in 40f - 50f weather but I've changed a couple of things since. Just sharing!
Brvndxn
B
Azusa California
2017 Honda Civic Hatchback Sport CVT
What intercooler do you have ? I have the prl cobra so i would probably want to get the prl intercooler too if you really think it would make a big difference, ive also been debating if i want to install my turbo blanket due to maybe the chance of oil getting on it and catching fire
Myx
Delaware
I have the Depo Racing intercooler. I recommend going with the PRL intercooler due to not reading about any issues with it and their reputation. My intercooler is great and exactly what I wanted. However some of the bands were to small and one actually came off my turbocharger outlet. I've since put my own band on it. I wouldn't want to see anyone else in that situation. The intercooler, piping, etc is awesome though and works very well. If I had to do it all over again, I'd purchase the Depo Racing Intercooler.....again (In case anyone asks).
Never heard of a turbo blanket catching fire. I have one installed. Just looked after reading you post and found this thread....
Turbo Blanket Catches Fire
On that note, don't install it. Better safe than sorry.
charleswrivers
Charles
Kingsland, GA
Good data points on the intercooler. I know the 90-100F days here in GA have really taken the edge off how well the Si's version pulls. In the winter, I feel like the car pretty much has the perfect amount of power for the platform. In the summer... it leaves me wanting a bit.
The TSP tune definitely feels softer on the throttle. It's lacking just a little bit of the "jumpiness" my KTuner setup had
Not 100% sure... but i think the difference was either quick spool being disabled or partial throttle boost wasn't at the most aggressive. It makes for a more linear power delivery but that would have been my only real criticism on my Si version as well. The 23# basemap was snappier... but it ran out of steam over ~5000 RPM.
Not sure what the peak number difference between the Si/non-Si versions... but it sounds like it's character is very... very similar.
I guess the bottom line here is that the only way you'll get a tune that's perfect is with a custom tune. The TSP tune clearly fixes the fizzled out top end of the KTuner base maps. But those user adjustable spool, turbo and part throttle tweaks on the base KTuner tunes give it a punchier feel down low.
What would really be cool would be TSP allowing some user adjustability of part throttle turbo response and early spool for an improved low end feel. That would take the tune from a long triple to a home run!
varge
George
Greece
Civic 1.5T 4D Elegance EUDM
I guess the bottom line here is that the only way you'll get a tune that's perfect for you is with a custom tune. The TSP tune clearly fixes the fizzled out top end of the KTuner base maps. But those user adjustable spool, turbo and part throttle tweaks on the base KTuner tunes give it a punchier feel down low.
Punchier down low when going WOT from low RPM or punchier like part-throttle response ?
Part throttle response at lower rpms.
nyamwaikinn
Jerald
San Jose, California
2018 Honda Civic Hatchback Sport(Sonic Gray)
A little background for those who haven't kept up with my postings. I was the guy who made topics like...
https://www.civicx.com/threads/second-class-citizens-lack-of-aftermarket-cvt-tunes.30667/
and this... https://www.civicx.com/threads/aftermarket-tunes-for-the-cvt.29655/
My basic beef being that the owners of tuned CVT's weren't getting much love from the pro tuners. I was definitely jealous seeing MAPerformance and TSP creating their own off the shelf tunes for the Si. And look, I understand why this was the case. Sure we have a turbo but the Si is the performance variant. I knew I was fighting an uphill battle, but in the end TSP and DRob stepped up and made my wish come true. Huge props to them.
I ordered the TSP Stage 1 tune yesterday. The process is very quick and painless. Just check off whether you have a street or race maf setup, your ECU software and then add your tuner unit's serial number. TSP emailed me the tune in just an hour or two. Great service from them as always.
My car: 2017 EX-L CVT 1.5 Turbo / PRL silicone intake hose and aFe Pro Dry S drop-in / KTuner V2.
The plan was to be patient and wait til this heat wave passed but I couldn't wait and decided to upload the tune and test it this morning while it was cooler (but still 85+ degrees out). The upload to the ECU went flawlessly and my TSP tune test started. I have a loop I use which has a bit of everything. Curvy back roads, steeps hills, highway straightaways and city stop and go. Here are my observations after spending an hour behind the wheel:
First off, one thing was rather interesting. I noticed idle speed was slightly higher than before. And actually that was a good thing. The car has a tendency to idle really low (650-ish rpm) and it can sometimes feel shaky in the cabin at a stoplight. The TSP tune seemed to hover around 700+ rpm and it definitely smoothed things out.
I tested Map 1 and 2 and they were just as expected. Solid, smooth and with lower boost levels than the real star of the show Map 3. I love the option of being able to go from one map to the other on the fly and these reduced power tunes save a bit on wear and tear. I call them my "commuter tunes". This is the one feature that separates KTuner from Hondata.
But you probably don't care about Map 1 and 2 so here's what you've been waiting for... the full TSP Stage 1 tune impressions. Let's just say it was worth the wait.
Around town and at lower RPM, it feels SMOOTH. The power is there, no question, but at first I was surprised it didn't feel more "snappy". Again just an initial observation. Driving a bit more I began to get a better feel for the tune. Basically, you press the throttle around town and it goes nicely (and seemingly with little to no discernable lag). Under 3500 rpm it basically feels like a smoother version of the Ktuner 21 with aggressive adjustments. Put your foot into it a bit deeper and away she goes.
The tune really wakes up above 3500 rpm and especially after 4000 rpm. You go from a smooth and polished low rpm feel to a bit of a monster. It's very impressive. Fun and confidence inspiring at the same time. I never pushed the tune too hard but I can tell you a nice little pull I did from 55-100 mph put a smile on my face!
During the entire one hour loop, K. Control basically was rock solid at .49, which is perfect. At the end of the loop, I checked my MPG's and I was at 40 (I did take it easy for a good portion of the drive). One thing I noticed was that fuel trims pretty much were in the minuses most of the drive. The numbers were decent enough (LTFT at - 4) so maybe I was running a bit rich due to the high ambient temps? No biggie, really.
For $80, this is a must have for anyone with a 1.5T non-Si looking for something beyond a base tune without the expense of a full-on custom. It definitely gets a
rating from me. :thumbsup:
Hey gtman! Just curious, does the cvt go faster in d or s? Im deciding if I should buy the ktuner v1.2 with the tsp stage 1 non-si ( my sport hatch is hitting 30k miles soon) :(
Honestly, I drive in D most of the time. I do use S from time to time but it kills mpg's a bit. Is S faster? Well, it does keep the revs higher so it does tend to feel a bit quicker.
As far as getting a KTuner, that's a no-brainer.
r.camlin
Rob
New Jersey
2019 Civic Hatchback Sport
“S” drive accelerates a little faster and has a little more throttle response, as well as keeping the RPMs higher and imaginary gear ratios tighter. Also enables the use of the paddle shifters if you have them. With the higher RPM you'll engage boost a little quicker and it'll feel more aggressive since you're starting out closer to the power band.
And yeah, as far as KTuner and TSP Stage 1, 1000% yes.
Nathan le
Honda boy
2016 civic touring
Hi, gtman what the max boost you hit for tsp stage1 map3? Thanks
I actually haven't datalogged that yet. Hopefully others can chime in who have.
dallasjhawk
Royse City, TX
from watching my V2 I feel like it peaks at 26 for a smidge but more like 25.5 tapering down
