H&R Springs for 2016 Civic coming in 2 months time
Thread Status:
Not open for further replies.
  1. Administrator
    Administrator Administrator
    Staff Member
    Apr 1, 2015
    799
    2,057
    Occupation:
    CivicX Admin
    CivicX.com
    Admin
    Honda
    For anyone looking for lowering springs, H&R springs for the 2016 Civic sedan will be available in approximately 2 months time.
  2. civvie
    civvie Senior Member
    Apr 19, 2015
    93
    civic
    Cool. Any other info? How much lowering? Progressive or linear springs?
  3. Design
    Design Senior Member
    Sep 28, 2015
    3,127
    2,704
    Southern California
    09 MS3, 17 ABM Si Sedan
    H&R usually does mildly progressive or two-step linear to ensure the spring maintains compression at full droop. We should expect the same with the upcoming 10th Gen.
  4. 10thG
    10thG Senior Member
    Apr 15, 2015
    268
    98
    Riverside California
    2016 Civic
    What about the 2006 Civic Si springs used on the Galpin Honda Civic? Can those be used and how would they compare to H&R?
  5. OP
    Administrator
    Staff Member
    Apr 1, 2015
    799
    2,057
    Occupation:
    CivicX Admin
    CivicX.com
    Admin
    Honda
    The Galpin customized 2016 Civic ran 2006 Si cut springs. They had to be cut to lower the car. Obviously that's an all-show type of modification since the car was being used for display purposes only.
  6. s2ker
    s2ker Senior Member
    Apr 2, 2015
    93
    Long Island, NY
    AP1 S2000
    Cut springs :thumbsdown:. That's definitely all show / no go. Guess they didn't have a choice since there's no lowering springs available yet.
    But Coilovers are the way to go anyway for height adjustability and an optimized shock/spring pairing.
    Design thanked this.
  7. Design
    Sep 28, 2015
    3,127
    2,704
    Southern California
    And ironically, I've found most budget CO's up to $1K are "cookie cutter" designs with poorly matched dampers and springs. Seems we can always tell which ones are poorly engineered from the single adjustment knob for both compression and rebound. Just a fancy way of saying they couldn't dial out crosstalk from their damper/valving. Some of the shock dynos I've seen from the Taiwanese brands are flat out scary. :(
    AirCooled thanked this.
  8. RallyeRed
    RallyeRed Senior Member
    Nov 21, 2015
    459
    269
    Arizona
    2016 Honda Civic Touring
    Have their been any other leaks as far as lowering springs go? Any other brands?
  9. bmcqueen22
    bmcqueen22 Member
    Jan 18, 2016
    Honda Civic Si
    Any updates with H&R?
  10. staged84
    staged84 Senior Member
    Jan 13, 2016
    92
    NJ
    Civic touring
    Does it usually take this long to develop?? I thought we would have it by now.
  11. CHAMP_FC1
    CHAMP_FC1 Member
    Jan 18, 2016
    26
    CORONA/EASTVALE
    2016 CIVIC SEDAN EX-T
    Taking forever
  12. RallyeRed
    Nov 21, 2015
    459
    269
    Arizona
    I don't know about you, but I'm glad companies are taking their time with suspension parts. If there is any aftermarket part that requires a lot of testing, it's springs. They have to match the spring rate to the new, shorter spring. If they don't and just release it, you could be bottoming out all the time or destroying your struts.
    Honestly, I will be waiting for Swift Springs to release a set, or I likely won't be getting springs. Swift is the only company that I know of that tests their product extensively to make sure you won't bottom out or reduce the life of your struts. They also use a proprietary alloy for their springs, that will not sag over time.
  13. biffosaur
    biffosaur Senior Member
    Feb 22, 2016
    156
    89
    Dearborn
    2010 Fusion Sport, 98 Civic Dx (turbo/Blown), 98 Civic Ex (Blown), 87 CRX HF, 94 F150 302
    So just because I can actually answer on this one (Springs are one of the parts I actually work on every day) they are really really really simple.
    You really just need to figure out rate and load...the height is directly related to those two. As long as your stresses are within your material limits, you're good.
    Also it's obviously got to fit lol
    They most likely have taken an OEM spring, measured the package space, and are playing with different rates and loads...shouldn't take toooooo long to find a sweet spot.
    Then they have them made (my guess is cold-wound because there's no tooling costs) and bada-bing-bada-boom you get your springs!
    2 months is reasonable, I'd say 3 is too. After that it's either become a non-priority or they ran into some roadblocks.
    RallyeRed thanked this.
  14. RallyeRed
    Nov 21, 2015
    459
    269
    Arizona
    Thanks for the info! :)
  15. bmcqueen22
    bmcqueen22 Member
    Jan 18, 2016
    Honda Civic Si
    This is getting old...
Thread Status:
