Grinding on Start Up!!!CTR Rev Matching and Emissions Issues w/Check Engine light AGAIN.
  1. CivicTypeRMan
    CivicTypeRMan Senior Member
    May 24, 2017
    151
    110
    TN
    E350/Soon to be Type R
    #1 CivicTypeRMan, Dec 2, 2017
    Unfortunately this will be the 3rd time with issues. The infamous light illuminated again. However, this was much different. I pushed the clutch in and pressed the start button, the car immediately sounded like the starter and flywheel weren't mating properly. A large metallic grinding sound continued until the engine turned over from about three rotations. The Rev match and Check Engine light appeared and I cut the car off. I started the car again with no issue. I'll be taking it to Honda on Monday. I'll let ya'll know what code it popped and how they are addressing the problem.***UPDATE***... Didn't get the code, however, it was a detonation issue that resolved itself. TYSBJ. And NO, I DIDN'T OVER REV IT...
  2. jdmorangefever
    jdmorangefever Senior Member
    May 22, 2017
    402
    277
    Nevada
    93 eg, 17 type r, 16 crv
    Peoplehave posted here how the flywheel comes apart maybe same issue
    CivicTypeRMan thanked this.
  3. Acurately
    Acurately Senior Member
    May 2, 2017
    83
    88
    New Jersey
    3G Acura TL, 1G Acura MDX
    have you over-reved it recently, or at least redlined it before this startup?
  4. OP
    CivicTypeRMan
    May 24, 2017
    151
    110
    TN
    No, I moved it out from my garage. It sat for a day and then I started it up and the fault happened .
  5. TypeRinATL
    TypeRinATL Type R #1634
    Oct 23, 2017
    505
    289
    GA
    17 Civic Type R
    Yep, this is the starter ring disconnecting from the flywheel. Looks like it’s becoming a common issue on these cars unfortunately.
    :thumbsdown:
  6. NorthernEX-T
    NorthernEX-T Senior Member
    Feb 2, 2016
    3,582
    3,582
    Occupation:
    Wind Technician
    Canada, EH.
    17 Type R
    You must have over-revved it.
  7. Chee_hu
    Chee_hu Senior Member
    Feb 21, 2017
    887
    687
    Elk Grove, California
    Sherwin
    #611 Rallye Red CTR | 1998 Civic EX | 2007 Honda Fit Sport
    I highly doubt the OP would admit to it.
    02SilverSiHB thanked this.
  8. NorthernEX-T
    Feb 2, 2016
    3,582
    3,582
    Occupation:
    Wind Technician
    Canada, EH.
    17 Type R
    Shit happens tho. I’ve done it before in many Honda’s lol
    Chee_hu thanked this.
  9. Phantisy
    Phantisy Senior Member
    May 27, 2017
    691
    430
    Occupation:
    Something nerdy in IT
    Virginia
    Marshall
    '13 Honda Fit Sport, 17 Honda CTR
    Not hard to over rev on a missed downshift.
  10. NorthernEX-T
    Feb 2, 2016
    3,582
    3,582
    Occupation:
    Wind Technician
    Canada, EH.
    17 Type R
    That's not usually how it happens lol
  11. Phantisy
    May 27, 2017
    691
    430
    Occupation:
    Virginia
    Marshall
    Oh, I know. Just saying it can lol
  12. Skate1530
    Skate1530 Member
    Jul 28, 2018
    95965
    Jonathan
    Type r
    Will full throttle shifting lead to this?
  13. leehom
    leehom Senior Member
    Jun 17, 2017
    214
    122
    under your bed
    Honda, back at it again
    How is it possible to over rev on down shifts if rev matching is on? Or does rev match only work on shifts going up?
  14. Driveitlikeuboughtit
    Driveitlikeuboughtit Senior Member
    Jun 28, 2018
    800
    511
    2018 CW CTR
    A money shift is all mechanical - the rev matching works by revving when you drop the shifter into a gear. Your clutch is still out though, so you're in neutral. The rev match won't over-rev, but if you drop it in to 2nd gear and you're going 80, if you let go of the clutch you will mechanically over-rev. No stopping that.
    haojohn and leehom thanked this.
  15. EnjoyDriving
    EnjoyDriving Senior Member
    Sep 3, 2018
    512
    124
    Minnesota
    2018 CW FK8
    What is the limit for over rev? Beyond the red mark right? Its really hard to over rev unless u totally forget to shft or down shift to a wrong gear, or felt asleep at wot?
