GPS accuracy issues
nickjohn35
Nick
Cincinnati
Current: 2017 PMM Typer R. Former: 2004 350Z
Ever since the day I purchased the R, the GPS gets majorly confused and will show me no where close to where I’m really at. When I dropped my car off last week for the harness update I asked them to perform the radio/navi service bulletin, which apparently updated the software. Well that didn’t help. GPS is still confused so I emailed Honda and Honda America called me yesterday and recommended the next thing I try is a system reset.
Has anyone tried this with success?
TurboRon
Ron
Miami
2017 Civic Sport Touring
Tried it, no luck. Changed the GPS antenna and complete unit - no luck. :banghead:
nickjohn35
nickjohn35
Nick
Cincinnati
I ended up doing the reset and it worked great for about two weeks. Now it’s back to being all sorts of messed up...
Machdk
Mads
Silkeborg, Denmark
Honda Civic Prestige 1,6 Diesel 2018
Have the same issue, dealer got me an new antenna last week, but it still gets super confused.
Yesterday when I drove home, it could not get a gps fix for 35 mins.
Got the feelin it's the build in compass,with the build in Garmin software, that is the rootcourse. When I look at the compass in the infocluster, it sometimes shows multipledirections real fast.
If the inertia system overrules the gps as per default, and the 2 positions from GPS and inertia does not match within the built in parametres, it could explain the issue.
But it super annoying, especially when my local dealer look at me like an idiot
SCOPESYS
Geoff
MD
Is there not a diagnostic that shows the Satellite numbers and strengths. ?
If that is OK, then it must be a faulty GPS system, or interference getting into the system, and it needs to be replaced.
Machdk
Mads
Silkeborg, Denmark
Yes. There is a satelite info status thing.
Its really weird. Even though it Seest all satelites it still cant get a fix
SCOPESYS
Geoff
MD
Yes. There is a satellite info status thing.
Its really weird. Even though it Sees all satellites it still cant get a fix
Well, if it is getting a good signal strength and sufficient Satellites, then the Antenna and it's connection (and power) are OK.
So it must be a defective head Unit.
Does you PHONE get a good GPS Position, if you use it in the car with the engine running ??? ( Could possibly be Interference ) ??
GermanCivic
Germany
Honda Civic X Sedan
Is there a final solution for this problem?
There were many people who got the head unit replaced and GPS antenna replaced and it did not help:
At least with my phones, the GPS signal works perfectly well when the engine is running.
