Glovebox door rattles
cmatti2016
Michigan
2016 Honda Civic EX-T
When the weather is warm, say 70 degrees +, the door to the gove box makes a rattling noise. If I put my hand on the door it stops. So, I am thinking that the noise it is making is it rubing against the plastic that the door sits up against. Anyone else have this issue? Any suggestions on how I can fix it?
fitter_here
Ste-Anne-des-Plaines, Quebec, Canada
Civic LX 2016 Sedan
I had the same problem, very easy to fix, loosen the two(2) bolts under the glove box, push on the glove box cover while re-tightening the bolts.
have a good day
rhraziel
Charlotte, NC
2016 Honda Civic Touring
have a good day
Hi, I know this is an old post but are these the two bolts you're talking about?
https://imgur.com/a/xPrIsDX
Also, when you say "push on the glove box cover", do you mean the door of the glove box?
fitter_here
Civic LX 2016 Sedan
Yes, those two bolts, and apply pressure on the glove box cover while tightening the bolts.
It worked for me
rhraziel
Charlotte, NC
It worked for me
Awesome, I'll give it a shot this evening. Fingers crossed. It's been off and on but it took me over a year just to determine it was coming from the glove box.
rhraziel
Charlotte, NC
I retighted the bolts with a phillips head since I didn't have a socket wrench that could access the bolt on the right. So far no more buzz coming from the glove box. I wish I would have found this thread a long time ago!
