Getting High Beam Flashed when driving with Low beams
  1. FC3L15B7
    FC3L15B7 I'm a machine.
    Nov 22, 2019
    245
    144
    Occupation:
    Truck Driver, because Badass is not an occupation.
    Daniel
    2020 Honda Civic 2 Door Coupe Si / 1993 Chrysler Intrepid 3.5L
    Yep. They say the headlights have glare issues with oncoming traffic. I personally get blinded all the time from pick ups and SUVs, so fuck 'em all. :)
  2. ITGuyLevi
    ITGuyLevi Senior Member
    Aug 18, 2016
    55
    Occupation:
    IT Guy
    Georgia, USA
    Levi
    2016 Civc Touring
    When I first bought my '16 I was getting flashed constantly, so I went to a big parking lot and used a building to see how high up the were pointing. Adjusted them down a bit and it pretty much hasn't happened since (maybe 3 or 4 times in the past 3-ish years). I also had to adjust them a little bit more when I got it to the UK, but after getting back to the states I adjusted them back to a sensible level.
    If only someone would go around and adjust all these damn pick-ups and SUVs... There lights are quite literally at eye level.
    Drake thanked this.
  3. GotBoost?
    GotBoost? Member
    Oct 9, 2019
    Philadelphia
    Bill
    2019 Civic Si sedan, 1992 Chevy Blazer
    Thanks for the link. I noticed on that comparison that the '19 (which I have) came with halogen PROJECTOR while the '20 came with led REFLECTOR which may cause the excess glare.
    After much research I swapped in 'eye of Megatron' LEDs into my PROJECTOR housing and couldn't be happier. I drive enough at night and rarely get flashed... no more than with my previous oem halogen reflectors in '11 Altima.
    Higher quality LEDS have a sharp cutoff, so do projector housing usually. Reflector housings on the other hand bounce around light with much less precision. I can't stand when an older truck is behind me with LEDs stuffed into the original reflector housing. The brightness is EVERYWHERE. But I can seem to better tolerate newer vehicles with correctly focused led projectors.
    See the sharp/lowered left cutoff
    arpypat thanked this.
  4. RoB y4h3ll
    RoB y4h3ll Member
    Dec 31, 2019
    48
    Tyler Texas
    Deric
    2020 Honda civic Si sedan, 2016 Honda civic Ex
    Yea its the auto brights... some times they don't wanna switch back over to low beams in time lol.
    Just yesterday actually, Someone hit me with their brights down at a light at a 4 way for a few seconds... so.. lol I hit them back with my brights the remaining time left at the light as a revenge technique. It worked well. :)
  5. VooDuuChild
    VooDuuChild Senior Member
    Aug 31, 2018
    402
    260
    Occupation:
    Professional lawnmower racer.
    Westsiiiiiiiide
    2018 Civic Si, Boosted Street and Track Monster 91 CRX Si.
    I 100% agree. When LEDs are either not adjusted correctly, or put in housings that are not designed for LEDs, it really causes havoc. I just flash and roll down the window and flip them off. I'm about to put a three foot slim bar up front and start blinding them back....(well, not really, but that's what I wanna do). I am SO OVER the LED lights. I work 2nd shift so I drive in the dark daily and it's now my biggest driving pet peeve....it used to be idiots who don't understand how four way stops work...but LEDs takes the cake.
  6. Ultimate Warrior
    Jan 13, 2020
    Jared
    Honda
    I'm not so sure if it's too bright or poorly made by honda cause my Mercedes lights are brighter then my civic but it doesn't blind other driver's like my civic I think honda did a poor job of the aiming
  7. OP
    Fatheadrr
    Fatheadrr Member
    Oct 5, 2019
    Hastings, Minnesota
    Ryan
    2020 civic si sedan
    Its not auto brights from me. I usually run with that off as well as foglights off and still get Flashed
  8. nickname
    nickname Senior Member
    Apr 20, 2019
    198
    Houston
    '16 Civic Touring
    Yellow fog lights aren't ugly.
    They are legit af.
    As you may know, yellow light doesn't bother the eyes when reflected off fog. (at least that's the theory)
    tacthecat thanked this.
  9. nickname
    Apr 20, 2019
    198
    Houston
    '16 Civic Touring
    check ahparts.com
  10. EdwarDallas
    EdwarDallas Senior Member
    Oct 23, 2019
    118
    51
    Dallas, Texas
    Edward
    2020 Civic Si Sedan, 2016 HRV MT-6, 2015 Civic Si Sedan, 2010 Civic Si Coupe, 2004 Civic Si (EP3) AKA The Black Egg
    Is there a way to change this setting?? I know the auto-bright sensitivity can be changed.
    Edward
  11. tacthecat
    tacthecat Senior Member
    Feb 9, 2016
    1,184
    440
    Cheshire, MA
    '12 Civic Si Sedan, '98 Civic EX Coupe 5MT
    Not aware that the sensitivity can be changed but (from p172 in the Owner's manual):
    "You can turn the auto high-beam system off.
    If you want to turn the system off or on, set the power mode to ON, then carry out the following procedures while the vehicle is stationary.
    To turn the system off:
    With the light switch is in AUTO, pull the lever toward you and hold it for at least 40 seconds.
    After the auto high-beam indicator light blinks twice, release the lever.
    To turn the system on:
    With the light switch is in AUTO, pull the lever toward you and hold it for at least 30 seconds.
    After the auto high-beam indicator light blinks once, release the lever."
    EdwarDallas thanked this.
  12. Michaelagilmore
    Apr 3, 2019
    Washington Court House, Ohio
    Michael
    2019 Honda Civic Touring
    Personal preference legal or not. I dislike the mismatched lights so I changed out the fogs.
  13. SDAlexander8
    SDAlexander8 Senior Member
    Jul 11, 2019
    656
    457
    Occupation:
    Environmental
    Indianapolis, IN
    Steve
    2017 Civic Si Coupe
    I kinda like the contrasting colors of the DRLs and lowbeams.
    nickname thanked this.
  14. SDAlexander8
    Jul 11, 2019
    656
    457
    Occupation:
    Environmental
    Indianapolis, IN
    Steve
    2017 Civic Si Coupe
    Has anyone seen the LEDs they have wrapped around newer ambulances? Jesus shield your eyes at night around those. The brake lights fry my eyes out and leave me seeing blotches of light for 10 minutes.
  15. RoB y4h3ll
    RoB y4h3ll Member
    Dec 31, 2019
    48
    Tyler Texas
    Deric
    Lol.. dont see why that was so hard to understand ha
