leehom
- Jun 17, 2017
- 4
- 232
- 128
- under your bed
- Honda, back at it again
Boost is increased by 5 psi?
If you run this, please report back with your findings. I’d like to see where this will go with just FBO, factory fuel system and MAF, and pump gas.do you have any datalog you can share.
Curious to see how the fueling up top is.
I don't think they will man, from what I've seen in their replies...they are limited, apparently due to "politics" as it was statedIm trying to be patient with KTuner, because I really liked their work with the 1.5T SI. With every Hondata improvement, it's getting harder and harder though. I get not embracing anti-lag - it's dangerous. But then there was the advanced traction control, and now this.
I really hope that they're just saving it all for one big release.
Yeah, I had Ktuner, switched to hondata as soon as traction control came out...I would not bother holding out for anything new from ktuner.You and me both. I've been teetering on the fence of dumping ktuner and getting hondata. It's getting really hard not to. I just really don't want the hassle of selling the ktuner but I may have to.
lol, yeah, I routed the cable behind the dash and have that module sitting in the center area in front of the shifter...it works pretty good that way for me, but I know what you mean....Hondata has this feature as well, but I believe that you still need to leave their programming brick dangling from the ODBII port.
Be careful...I do worry some could get to carried away and blow their motor with this. I just wish my local tuner did work with flashpro, but he hates hondata. He actually convinced me to go with ktuner, lol...bad idea, glad I'm with hondata now...but I need to find a tuner that isn't biasedOh I just threw it on and went for spin. I have a throttle controller on the port so didnt log anything. I got a busy day tomorrow but ill see if I can post one later in day.
Yeah im running it. Ill try post a log later today. My test drive ,it seems to run smooth.If you run this, please report back with your findings. I’d like to see where this will go with just FBO, factory fuel system and MAF, and pump gas.
Well, my initial test, was short, I consistantly hit 24 , but not above. Before this tune I could hit 26. But i only drove it around 10 mins. Later today ill go out for more time and play and see. Same settings on this tune as old just checked the new box. But does seem to run faster.Would like to see what kind of boost and power levels we’d see on FBO cars.
nice, can't imagine, even more power, lolYeah im running it. Ill try post a log later today. My test drive ,it seems to run smooth.
i was under the impression that this was more for people with upgraded turbos who had the issue PRL had in the upper rpms and not for power on stock turbo cars but idk.If you run this, please report back with your findings. I’d like to see where this will go with just FBO, factory fuel system and MAF, and pump gas.
Listed my v2 for sale. Hondata here I come!I don't think they will man, from what I've seen in their replies...they are limited, apparently due to "politics" as it was stated
I asked hondata on the YouTube video for this whether this dyno plot was using the stock turbo and they said “yes”. (Didn’t give me any other context).i was under the impression that this was more for people with upgraded turbos who had the issue PRL had in the upper rpms and not for power on stock turbo cars but idk.
I may do a quick run with it though just for data purposes and see how different the parameters are.
I wonder what changes to suddenly increase top end power? I know that they mentioned MAF Scaling - how does that work? Are there any risks to that approach?I asked hondata on the YouTube video for this whether this dyno plot was using the stock turbo and they said “yes”. (Didn’t give me any other context).
I hope someone can throw this on a dyno with a basemap to see if there is more torque / power in upper rev range
the new updates disables lowering the air charge due to EGT. So under high load, high rpm, it stops the ecu from lowering aircharge (basically boost) to stop the car from having too high of an EGT. (at least that's what i read it as)I wonder what changes to suddenly increase top end power? I know that they mentioned MAF Scaling - how does that work? Are there any risks to that approach?
since horsepower is a result of torque and rpm,Does that mean that in theory, we could leave torque capped around 350-375lb throughout the entire RPM range (using the torque target table) to still achieve 400+ whp while keeping torque conservative?
I think a lot of people want to know this. Thanks.
Agreed. I want to confirm with Hondata that they're saying 400whp+ on stock internals is possible.since horsepower is a result of torque and rpm,
HP = (RPM x torque)/5252
there are two ways to increase HP. You either increase the max RPM or increase the torque. Since we are limited to at max 7k or 7200 rpm due to valve float, only way to increase peak HP is to increase torque.
So if you are able to keep boost up in the higher rpm and reduce the amount of torque drop off that we usually see, it would increase horsepower.
