GAS GUZZLER
  1. frontlinegeek
    frontlinegeek Senior Member
    Feb 25, 2018
    659
    258
    New Brunswick, Canada
    Jason
    2010 CRV, 2017 Civic EX Sedan Honda Sensing
    Nope. For fuel efficiency, pure gas is best. For power, E85 is best due to the extremely high octane rating of ethanol and its burn rate.
    solidconceptgroup and hicompb18c1 thanked this.
  2. OP
    solidconceptgroup
    Jul 2, 2019
    Occupation:
    Novice Racer...
    So. Cal
    Bert
    FK8, Accord V6
    I feel yea... I wanted to get an opinion from other drivers what their avg. MPH were.. maybe calling the rocket a gas guzzler was the wrong approach, but driving an accord V6 for so many years spoiled me... given the fact this car is a race car.. I felt as if I was running through gas super fast, but I guess I'm using the car more efficient than others..
    Not to mention I wanted to know if E-85 was a better option, clearly it isn't..
  3. OP
    solidconceptgroup
    Jul 2, 2019
    Occupation:
    Novice Racer...
    So. Cal
    Bert
    FK8, Accord V6
    Not quite, but when your use to getting 35 mpg out of your accord, 27 mpg is a definite guzzler.. apples to oranges tho...
  4. hicompb18c1
    hicompb18c1 Senior Member
    May 22, 2017
    272
    191
    San Diego
    2019 Civic Si Sedan, 2018 Accord LX (wife's)
    Yeah, E-85 is a big no in my book, for mileage I mean. Lots of friends who ran it in Subarus and they were getting about 17%-20% worse MPG on E85 than they were with regular 91.
  5. Socialconflicts
    Apr 19, 2019
    André
    Civic hatchback
    I'm getting 34 on a 1.5 hatch...
  6. frontlinegeek
    Feb 25, 2018
    659
    258
    Jason
    I should tell you that when I am whipping my 2.0 NA K20C2, I can get as bad as 23 - 26 mpg. I have less than half the overall power of you. I drive it on 91 octane but only to guarantee I am not getting any ethanol. If I drive normal in the city, I get about 30. If I am cruising on the highway and not blasting all over the place, I can almost get 45.
    The one thing I would remember is the power profiles are so different on the 3.5L V6 vs the K20C1 that they are not even remotely comparable. The V6 would barely have to work to deliver the power needed when just driving it casually. 20/30 rating for the Accord with the 3.5 and the CTR is rated at 22/28.
    And I can say for me, if I had a CTR, I would likely be in full smiles per hour mode all the damned time.
    solidconceptgroup thanked this.
  7. krees
    krees Senior Member
    Sep 17, 2017
    595
    495
    FL
    2018 Civic type r & 2017 Subaru WRX
    I checked the computer for my average and I'm at ~26-27mpg which is probably 24-25mpg in reality which I'm satisfied with.
    My driving is equal parts "old man Sunday drive" and " Speeeeeeeeeeeeeed!".
  8. Puma
    Puma Member
    Apr 8, 2019
    Western Mass
    Brandon
    2019 Civic Type R
    For real, same here. I do about 90% highway driving and average roughly 18.5mpg. I took a trip last week that was all highway and averaged 32mpg on that tank. I’m lucky if I get 200 miles on a single tank. But 10-11 gallons at 18-19mpg is right around that 200 number. I’m perfectly happy and content with that. Small tank, so obv we’re going to be at the gas station filling it up more often. But that mpg on this car is pretty decent for what it is, and how I drive it! Lol
  9. 23Red
    23Red Senior Member
    May 2, 2018
    333
    241
    AL
    '18 Civic Type R, '06 S2000 turbo
    This. MPG rating was the last thing on my mind when I bought my car. If fuel economy was my priority I'd get a Prius.
  10. tinyman392
    tinyman392 Senior Member
    May 21, 2018
    752
    402
    Illinois
    Marcus
    '18 Civic Type R (RR)
    I'd get a Corolla Hatchback Hybrid. Same system as the Prius without being a Prius :p Though then I'd double back and get the Corolla Hatchback manual :p
  11. AdamD19DFK8
    AdamD19DFK8 Senior Member
    Jul 11, 2019
    Maryland
    Adam
    2019 FK8 Type R, 2007 Civic Si sedan
    27-29 is great. I usually end up getting 22-23. I got close to 30 one trip where I filled up and reset the meter and tried driving as gingerly as possible. It was the 4th of July and cops are just looking to pull you over.
    Any other time I'm far from anything moderate. I floor it whenever opportunity arises, I stay in the mid range of the gear if I'm driving spirited, and I don't shift into 6th unless I'm at or very close to 70mph.
    I'm about to recieve hondata (today I hope! I brought my laptop to work just in case) so I imagine gas mileage will be staying in the low 20s lol
  12. MutatedMango
    MutatedMango Senior Member
    Mar 24, 2019
    225
    83
    Occupation:
    Student
    Philadelphia
    '19 Civic Si coupe
    Agreed, if I'm trying I can hit 40mpg pretty easily in the Si
    krees thanked this.
  13. willskiGT
    willskiGT Senior Member
    Jul 1, 2019
    113
    63
    Occupation:
    Corp Strat/Bus Dev
    Atlanta
    2019 Civic Type R #26262
    You can't even run pure E85 in these cars - there is not enough fuel pump (and likely fuel injector) capacity to do so, and the ECU will not adjust for it without a tune.
    E85 has lower energy density than gasoline, so you burn more of it to cover the same distance in your FK8. You would need a larger fuel pump and injectors, and you'd get worse gas mileage.
    29mpg is great. I get around 30mpg on the highway when keeping it to 80 or so. Last weekend I did 90 miles of driving on mountain passes and averaged just under 9mpg. Was a bit surprising, given my old RS4 would usually return low double digits on the same roads.
  14. 1981CBX
    1981CBX Senior Member
    Apr 20, 2019
    74
    39
    United States
    William
    2017 Honda Touring Coupe (owned) 2018 Accord base model (leased) 1981 Honda CBX motorcycle
    Apologies in advance for breaking in on a type r models forum, but I was looking through E 85 threads and thought I would reply regarding the fuel consumption I’m getting with a 2017 Honda touring coupe with mods regarding E 85. We CLIMBED up to 40.8 miles per gallon while doing 80 miles an hour on interstate 65 from Wisconsin to Louisville Kentucky. E74 ish.
  15. jinderC
    jinderC Guest
    27 is not a guzzler!
    are you drunk? I don’t know what you expect from the K20C1? It is designed for maximum power and extreme performance.....just be happy it’s pretty damn decent on fuel given how savage the CTR is overall.
    Sell the CTR and get a insight and be happy. This car isn’t made for people like you.... hate to be brutally honest but it’s true.
    davemarco thanked this.
