full review, writeup, and installation steps: ctr subs, amp, center channel, and door speakers
  1. ctrmofo
    ctrmofo Senior Member
    Mar 21, 2018
    1,787
    2,384
    Occupation:
    private equity
    planet earth
    '13 lambo lp550-2, '18 honda ctr cw (r-12321), 14' porsche cayman s, '16 porsche macan s, '13 mini jcw nme stage 1, '15 audi s3 apr stage 2, '15 audi q3, '12 monster 1100 evo, '16 triumph thruxton r, deposited for '19 lambo huracan performante
    pioneer dual voice coil sub and rockford fosgate amp installed. wow...just wow!!!
    my full review, writeup, and over 60 pics of step by step installation are here...enjoy!
    ceravis, JaimeD, HumbleSage and 15 others thanked this.
  2. OP
    ctrmofo
    Mar 21, 2018
    1,787
    2,384
    Occupation:
    private equity
    planet earth
    AMP TUNING:
    RF sends a tuning CD in the amp package, but CTRs do not have CD players obviously. Instead, go to this link for the tuning instructions and download the zip file in the format you'd like. Unzip and choose the "40 Hz @ 0 db" file to add to your smartphone or a USB stick to play in the HU following the tuning steps.
    http://rftech.custhelp.com/app/answ...n.-set-up-procedure-to-adjust-amplifier-gains
    Clydester88 and HRace thanked this.
  3. preeble
    preeble Member
    Sep 16, 2017
    40
    Lehigh Valley, PA
    Steve
    T4R
    amazing write-up!
    ctrmofo thanked this.
  4. Muggsy
    Muggsy Senior Member
    Nov 27, 2017
    356
    316
    VA/DC
    Gary
    2018 PMM CTR, 2000 Lexus GS400
    Thanks so much for this! I've been wanting to upgrade the stock sub but knew it needed an outboard amp, and wasn't ready to dive in without step-by-step instructions. This is exactly what I needed.
  5. SalemTypeR
    SalemTypeR Senior Member
    May 19, 2017
    223
    270
    Occupation:
    Forester
    Salem, Oregon
    Own: ‘17 PMM CTR, 2013 White Honda Civic EX
    Thanks for the write-up & how to photo album. Just what I needed to motivate me to up grade the sound system. I love to hear a great stereo in the car since that is my main pleasure while driving this amazing machine. I have replaced the foam insert with a oem spare, have any ideas where I could put the amp instead?
  6. megaphone
    megaphone Senior Member
    May 15, 2018
    126
    57
    Orlando
    CW CTR R-16412
    Thank you so much for doing this! I’m about to tackle this this week but I will be installing a JL Microsub+!
  7. tdsounds
    tdsounds Member
    May 2, 2018
    41
    Gulf coast
    Woody
    2018 CBP Civic Type R
    Does the trunk still rattle? Or all that foam installed eliminated it? Trying to see if I may need to dynamat the trunk bottom.
  8. OP
    ctrmofo
    Mar 21, 2018
    1,787
    2,384
    Occupation:
    private equity
    planet earth
    Couple suggestions would be the side corner flat areas depending on size of your amp. I test fitted my RF amp which is compact and fits well either side. You could also mount it on either wheel jump off the floor if you’d like.
    Also, behind the sub enclosure itself is a good spot on the sheet metal. There’s plenty of space behind it and reinstall the enclosure in front of it to completely hide the amp.
    SalemTypeR thanked this.
  9. OP
    ctrmofo
    Mar 21, 2018
    1,787
    2,384
    Occupation:
    private equity
    planet earth
    One thing to note, pull the 8 gauge wire the reverse direction vs what I did. Pull the wire hanger from the fender side not from the interior side. Reason being it will pull the grommet out of place and is a bitch to put back into the hole if you pull from inside the car.
    jinderC thanked this.
  10. OP
    ctrmofo
    Mar 21, 2018
    1,787
    2,384
    Occupation:
    private equity
    planet earth
    my trunk didn't have any rattles before whatsoever but wanted to be sure with the new sub. yes the foam definitely helped and still no rattles. from the outside hardly hear the low frequencies even.
    sound deadening definitely will help prevent rattles. i plan to go back in the near future to line entire trunk with soundskins pro and tighten everything up even more and to reduce road noise...especially given the trunk does not have a full hard cover.
  11. OP
    ctrmofo
    Mar 21, 2018
    1,787
    2,384
    Occupation:
    private equity
    planet earth
    here's the relative size of the rf amp just so you can get a feel.
    jinderC, UFO CTR and SalemTypeR thanked this.
  12. remc86007
    remc86007 Senior Member
    Mar 18, 2018
    436
    284
    Jacksonville, FL
    Ryan
    2018 Civic Type R
    ^ Are your hands more Trump or Rubio sized?
    On a more serious note: Thank you for posting this! I might consider doing this in the future. The factory system really sounds subpar to me. Any idea how much total weight this added to the car?
  13. OP
    ctrmofo
    Mar 21, 2018
    1,787
    2,384
    Occupation:
    private equity
    planet earth
    mine are rubio ;-) exact dimensions of amp are: 8-5/8"W x 1-5/8"H x 4-5/16"D
    just 3 pounds added from the amp...that's it! the pioneer sub weighed about same as stock one based on feel in my hands holding both. overall it's insignificant ;-)
    remc86007 thanked this.
  14. Chee_hu
    Chee_hu Senior Member
    Feb 21, 2017
    914
    709
    Elk Grove, California
    Sherwin
    #611 Rallye Red CTR | 1998 Civic EX | 2007 Honda Fit Sport
    Awesome job, OP! Thank you!
  15. UFO CTR
    UFO CTR Senior Member
    Oct 12, 2016
    2,532
    1,855
    San Frrancisco, CA
    2017 CTR#1348
    you can do this from the cabin side too...just gut a bic pen and turn it into a "straw" with a pointy side...then poke the pointy "straw' thru the grommet, then feed the 8ga cable thru the center of the straw, and lastly, pull both (straw and cable) out from the fender end.
    EDIT:
