Fuelled up civic 2016 with E-85. Is that a problem?
  1. terminatorxi
    terminatorxi New Member
    Jul 8, 2019
    Des Moines
    Rahul K
    Honda Civic 2016
    Hi,
    My wife accidentally fuelled up my Civic 2016 with E-85 fuel. The dashboard started showing various errors:
    1. Emissions System Problem
    2. Hill Start Assist Problem
    3. VSA problem
    4. EPS problem
    5. Brake hold system problem
    6. Brake system problem
    Took it to the Honda service center. They mentioned $700 for draining the fuel and induction service.
    Is this necessary?
    Some of the local auto care centers mentioned to go ahead and add normal gas to reduce the ethanol content.
    Will this work?
    Any suggestions are welcome.
  2. TypeSiR
    TypeSiR Senior Member
    May 15, 2017
    1,308
    888
    Occupation:
    Car Driver
    1.5T Civic, CTR, MX-5, Fit
    #2 TypeSiR, Jul 8, 2019
    Go to Harbor Freight and get one or two 5-gal gas cans and a liquid transfer pump and siphon out 5 to 8 gals. After that, fuel up the tank (Civic) with regular gas. If you choose to only siphon out 5 gals, the car will run okay but maybe a little lean until the next fill up (regular gas), hence my suggestion to buy two 5-gal gas cans to siphon out 8 gals. Car will run normally with up to 4 gals of e85 and 8 gals of regular gas mixture.
    What do you do with the siphoned out alcohol? You don't drink it. Put it back into the car 2 gals at a time after each fuel up and driving for 70 miles.
    https://www.harborfreight.com/5-gallon-gas-can-67997.html
    https://www.harborfreight.com/multi-use-transfer-pump-63144.html
    terminatorxi thanked this.
  3. OP
    terminatorxi
    Jul 8, 2019
    Des Moines
    Rahul K
    Honda Civic 2016
    Thank you for the reply.
    So would the warnings automatically stop after the ethanol level goes low?
    Or do I need to manually reset it from somewhere?
  4. TypeSiR
    May 15, 2017
    1,308
    888
    Occupation:
    Car Driver
    Yes, they should go away after fueling up with normal gas. May need to drive it a few miles after normal gas fill up before returning to normal.
  5. hobby-man
    hobby-man Senior Member
    Jun 20, 2018
    670
    464
    Mississauga, ON
    2018 Sport Touring Hatchback 6MT
    I was also going to suggest a siphon. Not sure who has siphoned from these new civics yet but the capless system might be a bit of a problem. Maybe put the emergency funnel in, and then siphon through that? I'm guessing it's sort of a double flap system.
    REBELXSi, shoegazer and terminatorxi thanked this.
  6. shoegazer
    shoegazer assistant to the assistant manager
    Sep 5, 2018
    542
    251
    Raleigh NC
    2018 Civic LX Coupe 2.0 (CVT)
    All of the above. But maybe get a really soft and flexible length of tubing from somewhere and gently do as advised above. Damaging anything with the EVAP system can be just as costly.
  7. 87elco
    87elco Senior Member
    Oct 25, 2018
    1,233
    467
    Jersey/Virginia
    Tj
    1987 el camino ls swap, 18 civic 6speed, 86 Porsche 911 (euro spec)
    I feel your pain I had a girlfriend that filled her civic up with diesel before lol
  8. OP
    terminatorxi
    Jul 8, 2019
    Des Moines
    Rahul K
    Honda Civic 2016
    This worked.
    I added premium fuel in my half tank and let it run a bit.
    All the warnings went away today afternoon.
    Thank you for all the help :)
    dallasjhawk and TypeSiR thanked this.
  9. OP
    terminatorxi
    Jul 8, 2019
    Des Moines
    Rahul K
    Honda Civic 2016
    Lol. Atleast mine filled it up with gasoline :D
  10. 87elco
    Oct 25, 2018
    1,233
    467
    Jersey/Virginia
    Tj
    Maybe this was I was in highschool tho :lol:
  11. turbociv910
    turbociv910 Senior Member
    Jun 25, 2019
    120
    93
    wilmington nc
    taylor
    19 SI, 99 ex b20v
    how.. the diesel nozzle is bigger and wont fit
    shoegazer thanked this.
  12. 87elco
    Oct 25, 2018
    1,233
    467
    Jersey/Virginia
    Tj
    Idk it was 10 years ago. And I think they're the same size.
  13. bbeem
    bbeem Senior Member
    Nov 11, 2018
    162
    60
    Occupation:
    travel tech
    Iowa
    Ben
    I thought the gas inlet hose has an anti siphon flap down in it. Where would be the best place to siphon? The fuel rail under the hood? Would I have to power the fuel pump? Thanks.
  14. zerointerrupt
    zerointerrupt Senior Member
    Mar 13, 2017
    118
    41
    Indiana
    2020 Si Coupe
    Diesel nozzle is bigger, at least by me it is.
  15. shoegazer
    Sep 5, 2018
    542
    251
    Raleigh NC
    Maybe use the funnel adapter and a lots of trial and error with a soft hose.
