Fuel pressure issues?? CEL on
  1. TheBigG
    TheBigG Senior Member
    Oct 24, 2017
    238
    117
    Sweden
    Gabriel
    Civic Type R 2017, Kia Optima Sportswagon GT 2017
    Wot at 3400 rpm is ok in every gear!
    Vortexhunter thanked this.
  2. ez12a
    ez12a Senior Member
    Jan 30, 2018
    715
    318
    CA
    18 CW Type R
    #32 ez12a, Mar 31, 2018
    not saying the type R is prone to this, but i've read mazdaspeed3 forums where they've blown up simply from using cruise control on an inclined freeway. We've come a long way for turbos to be so common place, i would hope they have engineered out some of these weaknesses.
    Personally/subjectively, my car feels best pulling above 3500. A question i ask myself, would an auto transmission downshift to do this pull? if so, then i might as well downshift too. You dont really hear about turbo equipped autos blowing, because well they downshift when they need to.
    Micah thanked this.
  3. Micah
    Micah Senior Member
    Oct 19, 2017
    2,102
    1,349
    Toms River, NJ
    Unless you want faster accelleration in which case you would typically downshift from overdriven gears.... assuming you care enough to know your ratios
  4. UFO CTR
    UFO CTR Senior Member
    Oct 12, 2016
    2,532
    1,855
    San Frrancisco, CA
    2017 CTR#1348
    Don't listen to these guys C, specially the guy with 37 mpg...you know that guys doesn't even touch the gas peddle with that kind of mpg! Your dealer is already fixing you problem...so no big deal! there are real people on this forum that want to help and not talk shit!!
  5. B3nji_Fc1
    B3nji_Fc1 New Member
    Jan 8, 2020
    Benji
    2018 Civic Si
    Hey bro I’m having the same exact issue but it happens to me on 4th
    I’m Im FBO 27won turbo and built motor/ idk if it’s low pressure fuel pump that’s going bad or maybe I have a bad fuel line, I was thinking of upgrading to a aem 340 fuel pump, but trying to figure out how to fix the issue
  6. ExileAeterna
    ExileAeterna Senior Member
    Nov 27, 2017
    90
    Occupation:
    US Naval Officer
    Pensacola, FL
    Dylan
    2018 Civic Type R
    OP, any more problems after replacing the pump? Im having the same issues now with bolt ons and a tune. Honda said I've probably reached the limit of the pump (dumb considering im only about 380HP and 400TQ.) They wont warranty the part obviously because of the tune and parts. All three times I got this error was passing someone full throttle on a slight uphill in about 4th gear. RPMs were probably about 3-4k.
  7. OP
    Raw 381
    Raw 381 Senior Member
    Jul 28, 2017
    125
    103
    Bay Area
    1995 Integra w JDM ITR 98 spec, 2017 Civic Type R
    Since you’re deep in mods I’d go ahead and just replace your high pressure fuel pump. That’s most likely the issue
  8. OP
    Raw 381
    Jul 28, 2017
    125
    103
    Bay Area
    No this HPFP was replaced back then under warranty. Haven’t had an issue since, currently on custom tune running vp101 pump with 5 track days and about 6k miles in so far so good. I’m at 368whp and 361wtq which my tuner said is the safe limit. So if you’re popping HPFP’s at 400 then he was right lol
