Fuel Filling Issue? **Not Overflow**
SpoolAndGo
US
2017 Civic Hatchback LX CVT
2017 Hatchback LX CVT with 12,600 miles on it and purchased in August 2017.
A couple of weeks ago my low fuel light came on as I was driving to the gas station. Usually, when this happens, it will end up taking around 10.3 gallons to fill up. The pump shut off at 9.4 gallons. Looking at the fuel gauge in the car, it was a "box" or two short from the very top of the gauge, past the F mark.
Today, I decided to get gas. The low fuel light was NOT on, but I was pretty low. The pump shut off at 1.5 gallons so I restarted it and it eventually shut off at 9.4 gallons again. Now, from the amount of gas that I had left, that seems about right, but the fuel gauge in the car is one "box" short from the very end of the gauge. I went to the same gas station, but used a different pump this time.
Any ideas if this is a car issue or just bad luck with pumps? I know there have been issues with fuel overflow, but this is different.
defeated
Navasota, TX
2017 Civic Hatch LX, 2007 Chevy Silverado
Definitely try a different station. I've been to stations that just have one funky pump, but sometimes it's all of them.
dj2819
DJ
New York
2019 Civic Sport Touring
I think this is a problem with certain type of nozzles, I went to several pumps that have the nozzle as I will post below. Depending on how much is inserted, it stops the pump prematurely.
This is the type of nozzle I have at my local shell stations:
If I insert the nozzle all the way in, the pump will usually stop very soon. The noise of the air escaping sounds similar to if the tank was almost full but this happens even if the tank is empty.
To get it to fill properly I have to insert the nozzle partially. The sound of the fuel flowing is much more normal now and the tank gets filled properly.
If I move the nozzle as its filling there is a tendency to stop the pump which is weird. Not sure if this is compatibility issue with this type of nozzle and the capless filler or what. I never had problems at these pumps before with any of my other normal filler type cars.
BailOut
Texas
2018 Civic LX-P
Has anyone experienced the "issue" where the fuel gauge declines very slowly at first (first half tank or so) and then increasingly accelerates as you near the empty mark? I've noticed this since I bought my 2018 coupe a few months ago, and it's most apparent comparing the F to the E mark. I can drive 100 miles and the gauge has only declined a few increments total. When it's closing in the E mark, on the other hand, I can watch the increments decline in real time as the car moves.
I called the dealership service dept to inquire about this behavior. They said as long as no warning/check lights were on there wasn't an issue, implying this was normal gauge functionality.
dj2819
DJ
New York
I think this is common for many new cars. My 2002 Acura TL seemed pretty linear. However my parent's '08 RAV4 and my '19 Civic seem to empty faster closer to E.
BailOut
Texas
2018 Civic LX-P
Gotcha. It's as if they consulted with a psychologist when designing the fuel gauge's change rate.
fjrman
Tennessee
2016 Civic 4 door LX with CVT
Was your car tilted to the left when you filled the tank? There's an air bubble in the tank when it's full. When the car is tilted to the left the bubble will be larger with less gas allowed in at fill-up.
Gas gauges are rarely linear since the tanks are not symmetrical. One inch of fuel equates to varying volumes in different elevations of the tank. I doubt Honda or any other vendor provides gas gauge software which accounts for the odd shapes of the tanks.
civicdriver_
USA, NC
2020 Honda Civic LX Sedan NA 2.0 L CVT
This happened in my old Jetta, if I remember correctly, it's really bad to let the fuel level go below 1/4 of your fuel gauge consistently. There's a chance that it could be a bad pump at a gas station or whatever but it could also be that you have air in your fuel tank from letting the fuel level drop low more than occasionally (I assume). I'd first try refilling with different pumps at different station but if that doesn't fix the problem then I'd bet that you have air in your fuel tank. Here's a video that explains the problem and shows you how to fix it yourself. It's not too complicated and you can save a lot of money that way!
If you'd rather just live with it like I did on my old Jetta, just remember what your fuel tank capacity is and always fill up when your fuel tank is at 1/2 and put in whatever a little less than half your max fuel tank capacity to be safe you don't overfill. Good luck and don't be too stressed about it!!
Edit: I just realized this post was from 2018 lol
TheCanadian
2020 Boost Blue Type R
I figured out the magic angle to make the fuel fill in my Type R. Tilt the nozzle about 30-45 degrees counter-clockwise when you are filling. So the hose going to the station is facing bottom-right (towards back of car).
My car would stop early until I figured out the magic angle.
TheCanadian
Trust me. Rotate the pump 30-45 degree's counter clockwise
BailOut
Texas
2018 Civic LX-P
Interesting point about the asymmetrical composition of fuel tanks causing the asymetrical decline rates on the fuel gauge. It makes sense.
Sing
Sing
Germany
Honda Civic Hatchback 10th gen 2017
I had this problem yesterday after driving a full tank empty, it could only fill up for 70% and thought something was wrong. I tried your method this afternoon and the tank is filled up full again nicely.
The sweet spot is indeed 30-45 degrees bottom right depending on the ground your car is standing on. Try moving a little to find out.
SethNES
Seth
Austin area
2019 Honda Civic Si Coupe
In my old 05 civic ex I installed a new fuel pump but didn't tighten it enough. So was gas smelling inside and when I went to fill up once it started pouring gas out bottom. I didn't know what to do so drove to friends house with gas trail. Let's just say after properly tightening gas pump and doing bounce test in back of driveway it was finally secure. Yea I'm a noob...
TheCanadian
Option 2 is to push it in deeply. Some gas pumps don’t seal full unless you really manhandle it
