FS: Phillips X-treme Ultinon LED Turn Signal Bulbs+Plug and Play Resistor Wire Harness
BlackBlade17
PA
2017 Si Sedan - Crystal Black Pearl
Hello, I have for sale 4 LED amber turn signal 7440 bulbs and a custom made plug/play resistor wire harness that prevents hyperflashing. I am getting full LED headlights and tailights so no longer need these anymore.
The bulbs are high quality Philips X-treme Ultinon. They are only sold over in Japan and are expensive, but well worth it. Not only are they high quality with a rich amber color, the diodes fire backward, utilizing the entire reflector housing and making them effective as replacements for halogens. Please note, I do not believe these fit the rear end of the coupe models. Sedans and hatchbacks have the 7440 socket in all 4 corners.
Here is there description link: https://www.ebay.com/itm/PHILIPS-12763x2-X-treme-Ultinon-LED-Bulb-T20-WY21W-Amber-Turn-Signal-180lm/293006735643?_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=20160908105057&meid=6db735ab20ec4dc88e661826efd7c88f&pid=100675&rk=6&rkt=15&mehot=lo&sd=333035016991&itm=293006735643&pmt=1&noa=1&pg=2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci:9da85623-258e-11ea-93d8-74dbd1807431|parentrq:331c857416f0ac3e2582d054ffa29e11|iid:1
The harness is made to order by DIYCarModz I discovered on this thread: https://www.civicx.com/threads/led-...esistors-w-oem-style-harness-all-trims.10290/ It is very heavy duty and doesn't get nearly as hot as those cheap little copper resistors that you need to physically splice in. It simply connects between the OEM 7440 socket and the LED bulb. You also only need 1 per side of the vehicle if installing LED bulbs in all four corners (I put these in the front as there is more room to mount them). These work flawlessly with the Philips bulbs and the month I had these installed I never had any hyperflashing at all. Very convenient and worry-free.
Price is $125 for everything shipped out the door. All the components together were pricey, but knowing I had high quality parts that wouldn't fail and illuminated light safely was worth it. I would like to sell the kit as a whole as well.
Thank you for looking.
Honda Civic 10th gen FS: Phillips X-treme Ultinon LED Turn Signal Bulbs+Plug and Play Resistor Wire Harness 20191222_152939
Honda Civic 10th gen FS: Phillips X-treme Ultinon LED Turn Signal Bulbs+Plug and Play Resistor Wire Harness 20191222_154145
Honda Civic 10th gen FS: Phillips X-treme Ultinon LED Turn Signal Bulbs+Plug and Play Resistor Wire Harness 20191222_154837 (1)
BlackBlade17
PA
Bump. Price lowered to $100 shipped.
BlackBlade17
PA
Weekly bump. $100 shipped out the door for everything. All packaged up and ready to go out.
BlackBlade17
PA
Monday bump :wave:
Syntek
Los Angeles, CA
2019 PWP Civic Si Sedan
so i can run all 4 and just need 2 resistors? I currently have iJDMtoy (bright as hell and also use projector lenses but I feel TOO blinding) ones which all 4 have resistors but also looking for alternatives.
BlackBlade17
PA
Correct all you need is the 2 plug/play resistors, one on drivers side and one on passenger side. I had them installed in the front as the space behind the tailight is fairly tight. But the boxes on the resistors are small and finding a spot to mount them in the front is easy IMO. I ran all 4 LED blinkers with no hyperflashing or any issues while I had them in. The individual who makes these plug/play resistors did a good job.
BlackBlade17
PA
Weekly bump, still for sale.
BlackBlade17
PA
Weekly bump
BlackBlade17
PA
Sold!
