Front sway bar endlink is leaking?
  1. yyalb
    yyalb Member
    Oct 10, 2017
    Michigan
    Albert
    10 gen Civic Si
    I kept hearing suspension rattle recently. I sent it to the dealer today but they didn't found "anything wrong". then I checked myself and found this. It's the upper joint of the frone sway bar end link, and all filled with grease. This couldn't be normal, right? Any idea on this problem?
    I have stock suspension and wheels, 26k miles, 2017 SI.
    [​IMG]GXN9Vr71sefXveeVdhBocq0PTiBf0LQHceRBtfCuvnuurgNJNrKleABg69MNlcodUjNOqSK6qvHBQzwNJ5=w1252-h937-no.jpg
    89bZgx1P1CmL9pyV0yDjmIvVaZHgejzLmZpJtCPmmavI4UmgF4BQO2LEHRslqJN3zEO9AAtKHqdJtOAjF8=w1252-h937-no.jpg
  2. Matthyahuw
    Matthyahuw Senior Member
    Apr 15, 2018
    661
    347
    Valley of the Sun AZ
    Matthew
    2018 Agean Blue Civic Si Sedan 2016 Omaha Orange Jeep Renegade Trailhawk
    depends...grime is normal
    you have to yank on it and see if it's loose.
    to be honest if they're bad, just get upgraded ones from MOOG (or elsewhere), even if you're under warranty
    only takes a few min each side
  3. OP
    yyalb
    yyalb Member
    Oct 10, 2017
    Michigan
    Albert
    10 gen Civic Si
    It's not loose but definitely has compliance, as sway bar is kind of soft. If it is bad, I just want to have them replaced under warranty, and switch to a better aftermarket option the next time it breaks.
  4. Matthyahuw
    Apr 15, 2018
    661
    347
    Matthew
    well, they DO swivel, so that's not an issue.
    I'm talking about 'clacking' when you yank them back/forth against the direction of the bolt
  5. OP
    yyalb
    yyalb Member
    Oct 10, 2017
    Michigan
    Albert
    10 gen Civic Si
    No there isn't any clacking. Anyway the leakage looks quite bad and I'll send it to the dealer again tomorrow. I'll keep you guys updated. Thx!
