mar6o
- Apr 1, 2018
- 3
- 123
- 87
- Tallinn, Estonia
- Civic 5D Elegance Navi MT 1.0
- Vehicle Showcase
So I swapped the original bulbs for LEDs, got cheap (long) ones which fit in a pinch, the seal with the rear part of the lamp was not tight, some water got in and I blew the marker light fuse (found out later that the rear markers are under the same fuse so I prolly rolled around with a dark rear for a while).
Replaced the fuse under the hood and got shorter LEDs which now fit as the original bulbs, so assembly is tight.
Problem is, the front right position light will still not turn on. It's not the bulb or the base (checked by getting it to work on the left), so I probably managed to short some wires down the line.
As it's a hassle to route the wires behind the bumper without removing it, has anyone had the same issue? Is there a place where I should start troubleshooting first?
