Those little nut type things,do they stay attached to the grill when I pull the emblem off, or ate they gonna fall off. I'm just trying to make sure I don't need to remove the grill to put it back on.
I did not remove the Grille. The posts pull through to the front. Or if you’re unlucky, they break off and fill into the plastic dust guard below.Those little nut type things,do they stay attached to the grill when I pull the emblem off, or ate they gonna fall off. I'm just trying to make sure I don't need to remove the grill to put it back on.
I mean.. as noted above, it is absolutely possible. But is it realistic for everyone? Probably not. Not to mention after all that work to get them off without breaking.. I proceeded to throw them away anyways.Ok, so it wasn't possible to get it off without breaking it. Luckily ,I was smart enough to have a new one ready just in case.
However,it doesn't seem like the pieces that will hold it in from the back are still there,I'm hoping when I push it in it will hold. Ill find out after I'm done dipping it in a few hours.
Lmao I was wondering why everyone cares to get them off carefully, if your getting the JDM emblem it covers the entire area anyway, as far as reinstalling original.... Good luck, I feel the pins and rear clip was only thing really holding it, the tape part came right off and doubtfully will hold it in place, if you want black emblems then just buy them, or try to dip it while it's on the car.I mean.. as noted above, it is absolutely possible. But is it realistic for everyone? Probably not. Not to mention after all that work to get them off without breaking.. I proceeded to throw them away anyways.
I dipped it while on the car and because it wouldn't snap off like it should,it left an edge that just kept lifting and lifting. Figured if I dipped the front and back ,with no edges it will last longer. I'm doing it in a pearl red so I can't just buy that. God I hope it goes back on ok,lolLmao I was wondering why everyone cares to get them off carefully, if your getting the JDM emblem it covers the entire area anyway, as far as reinstalling original.... Good luck, I feel the pins and rear clip was only thing really holding it, the tape part came right off and doubtfully will hold it in place, if you want black emblems then just buy them, or try to dip it while it's on the car.
I meant impossible for me,lol. It was in there so tight, I had it lifted less than a 1/4 inch and it just snapped the pin.I mean.. as noted above, it is absolutely possible. But is it realistic for everyone? Probably not. Not to mention after all that work to get them off without breaking.. I proceeded to throw them away anyways.
But on the other hand, if it wasn’t tight, people would be up in arms about Honda making loose badges and possible rattles. So I guess in the end, you can’t always have your cake and eat it too.I meant impossible for me,lol. It was in there so tight, I had it lifted less than a 1/4 inch and it just snapped the pin.
