Front grille coming apart.
Israel
Israel
California United States
Great find !
So the best thing to do is to reinforce all 3 the support brackets at the same time.I think if we would only reinforce the center one , i would only be a matter of time for the outer 2 to start bending too right ?
Whats the the name of the Center Bracket or part number?
hikaru
Shawn
Marietta
You just need to be creative to get similar bracket from Home Depot or Lowes.
The bracket has to be strong to retain its angle, and flexible enough make the correct angle to the extent that the grill sits flat in the Yellow rectangular area of the vertical bumper beam.
Honda Civic 10th gen Front grille coming apart. IMG_9904
marwek201
Slovakia
Honda
Last week I am changing front black grill due to parking sensor issue, Yes, it has improved hole but that doesnt matter when hooks on bumper are
cutted to minimum, I still have gap btw bumper and grill.
I have lucky, I call again to my service and they order whole new bumber I hope, that will be 2019 revision and will be improved, I hope this gap will be removed, I will let you know.
Rickmeister 48
Overlord
Newark De
2018 civic ex-t
Had to get my rear bumper fixed this week, but I was talking to the guy about the front bumper issue, they fixed mine a year ago and it's been fine so far.
But he was telling me that the design on the 16-18 front bumpers are so bad(which we all know), that the insurance companies are starting to demand that they use after market parts instead of oem.
He said though that most after market parts don't fit any better since they are designed after the OEM parts.
Nitori
Arizona
2019 Civic Si Sedan, 2016 Toyota Tacoma
Just wanted to post up my fix for this issue. I went from OEM to the Pro design grille to a Seibon CF grille and finally back to stock... So yeah, my bumper's tabs were toast.
After looking at it I realized a really stupid simple fix would probably work really well... Really all you need is for the bumper's tabs to be larger and this whole thing would be solved. So rather than heat gun, I gave zip ties a try, but simply stuck them through the grille's tabs and carefully fished them up and inside of the bumper, then loosely tied it off. I'm not using the zip tie to hold anything to anything else, so I didn't cinch them down hardly at all, in fact it seems like having them larger like this works better because there is very little tension.
Honda Civic 10th gen Front grille coming apart. bumper zip tie
What this does is make the theoretical size of the bumper tab impossibly huge such that there's no real way for it to unhook through the hole.
Will report back how it holds up, so far I have reinstalled the bumper and pulled pretty hard to see if I could get any deflection and there is none whatsoever.
Israel
Israel
Thanks Bro for the info
Chakra
2019 Civic Si
How's it holding up so far? Debating on if it is worth taking to the dealer... The grill clips have definitely scraped where they are supposed to be on my bumper...
The dealer I went to today told me it would not be covered since my bumper clips broke and that's physical damage... Gonna try another dealer today.
ApexEight
Anthony
Atlanta, GA, USA
2019 Honda Civic Type R
How's it holding up? Seems like a simple, effective solution.
procivic
Ventura, California
www.procivic.com
2017 Civic Si Sedan, Others
Going to try this. I have the Honeycomb style grill and its separating up top also. Thanks for this idea.
That is another good fix, even if you don't have this grille (the stock one can sag and separate as well).
Chakra
2019 Civic Si
I've been trying this and can still see a little separation from the grill and bumper, but it was not as bad as before. However, the rubbing got so bad that my one clips completely broke instead of only wearing down so that kind of explains the larger separation from before.
My dealer said it was due to a collision or me sitting on my car (physical damage), so no warranty for me... Lol..
Israel
Israel
Did you try the Zip Ties? If so can you still see a little open space?
Israel
Israel
Yes, there is a gap, but maybe more-so because I'm OCD about it. It would definitely be worse if I didn't have the zip ties though.
I see Bro is much less , I want to fix mine too.
Were the clips of your bumper broke?
Honda Civic 10th gen Front grille coming apart. 20200512_182952
Honda Civic 10th gen Front grille coming apart. 20200512_182946
