GeezR
- Mike
- Aug 3, 2019
- 3
- 109
- 66
- Cincinnati
- Honda Type R, Caterham, VW Touareg, Chevy Volt
I have done an unsuccessful search here trying to see if there is any consensus on front pads that ideally will last more than 3 track days. I dont care about dust, squeaking, grinding etc., the R is not my daily driver. Smooth, manageable grip that might get me though 10 track days (my typical season) would be my goal.
I already replaced my rears with Hawk race pads sold by Tire Rack and they worked well. The OEM's were metal on metal half way through the 3rd track day (I always ran with the 2 second VMS push). Since the rotors were badly scored, I replaced them with new Honda rotors.
I also added the Hawk front pads with lousy results, I think because I did not replace the very scored front rotors. Even though I bedded them in with 20 or so 60-30 mph, well spaced gradual stops, the performance was unnerving: massive judder up and down, so severe it shook the front of the car violently.
Eventually I got a brake failure warning, combined with a e-brake failure alert, ABS, failure, power steering failure, VMS alert, etc. But the car worked fine, no loss of any of those systems, tho the massive judder continued. I did numerous slow 60-30 mph slowdowns off-track after the first session with no real change. I was able to continue on track by backing my braking points off, downshifting for braking, etc but the shudder never got better and the warning lights/messages kept popping up 1/2 way through each session. More 60-30 mph slowdowns post event didn't fix it.
So I have ordered new front rotors and will likely replace the Hawk race pads since they have likely been scored by the rotors(wh/incidentally, are now much smoother).
So, my question: what should I use as my new front brake pad? Buy a new set of the Hawks and assume the problem was the worn rotors, or go with something else? If something else, what?
