Zeffy94
- Matt
- Mar 26, 2017
- 77
- 1,850
- 1,487
- Doylestown, PA
- 2017 Mazda3 GT Hatch 6AT, 2018 Honda Civic Type R (traded in)
- Vehicle Showcase
Maybe I’ve been hanging out in the Civic Si forum too much, but I’ve had this lingering question in the back of my head for awhile now.
If you’re at low RPM, say 2k, in about 3rd gear and you mash the throttle, is it bad for the clutch/engine? Not necessarily WOT either; more like 50-75% throttle pressure (according to the dashboard display).
I know that if you do this in an overdrive gear such as 5th or 6th it can be more harmful, but the other gears I’m unsure of. The only one that I would guess is fine is 1st gear for obvious reasons. I am guilty of accelerating at about 35-45% throttle at 2200RPM in 5th gear to maintain my speed, I don’t know if that is causing any harm or not.
I’ve read that you don’t necessarily want to be flooring it in a turbo car at low RPM in a higher gear because of something to do with boost pressure and the engine internals or something. Plus I think it causes the clutch to wear faster and cause it to start slipping?
I know it’s a dumb question
