It is essentially disabled at 15000 RPM since you will never go that high. You'll want to set it a little under your launch RPM limiter.
What 360 said about the RPM and the rest you are on your own. I don't want to be responsible if you damage your turbo by playing with the anti lag too muchany suggestions on what to set them to? im not too familiar with setting up anti lag.
Gotcha, thanks.What 360 said about the RPM and the rest you are on your own. I don't want to be responsible if you damage your turbo by playing with the anti lag too much
Scramble builds boost faster, especially at lower rpms. I think this would likely be a bad thing for the CVT. Can anyone with a CVT and tuning knowledge chime in here?Do the 2016 EX-T CVT models have a scramble feature too?
Probably not a great idea with the CVTGot a question is Scramble mode enable a good thing? novice question here lol
I don’t have the CVT. What is the concept behind the scramble mode? Can I let it enabled?Probably not a great idea with the CVT
Builds boost much faster and this means more torque at low rpms. That is generally considered a bad thing afaikI don’t have the CVT. What is the concept behind the scramble mode? Can I let it enabled?
Jum got it!! Will disable it!! What about anti-lag settings?Builds boost much faster and this means more torque at low rpms. That is generally considered a bad thing afaik
No. Google or search the forum to learn whyJum got it!! Will disable it!! What about anti-lag settings?
Tried google specific to this car but google keeps sending me to this exact post!! That is why I askedNo. Google or search the forum to learn why
