FlashPro for CTR tuning results
  1. alpinefd
    alpinefd Member
    Jan 5, 2020
    Walnut
    2019 Civic Type-R
    #631 alpinefd, Jan 12, 2020
    you are right ! it was the ignition timing.
  2. alpinefd
    alpinefd Member
    Jan 5, 2020
    Walnut
    2019 Civic Type-R
    in the turbo max ratio (temp) table is the X axis unit F or C?
    was thinking it's C, but maybe it's F?
  3. fiend busa
    fiend busa Senior Member
    Apr 22, 2017
    1,138
    413
    2018 Civic Type R
    @Hondata
    Hey Hondata, I flashed my car back to factory using online - restore factory
    Car now now constantly has brake hold and traction light, engine is barely running (cant go past 14kmh) and the car keeps acting like it's about to stall.
    Flash pro and ecu is now not being detected.i dont know what to do :(
  4. jasonjm
    jasonjm Senior Member
    Jul 29, 2018
    810
    387
    Pennsylvania
    Jason
    Type-R
    Also consider using the Hondata support forums first, here second. Also call the support number. If this is a real issue on some ECUs others would like to know.
    fiend busa thanked this.
  5. fiend busa
    Apr 22, 2017
    1,138
    413
    2018 Civic Type R
    Thanks for the advice. I will go to Hondata website (reinstalled flahspro and I can flash it again so I'll see what happens)
  6. jasonjm
    Jul 29, 2018
    810
    387
    Pennsylvania
    Jason
    Type-R
    Just wanted to chime in. This morning I was continuing to refine my tune (93 with light mods) and I happened to log some runs in 3rd from 20mph to the top of the gear. It’s 20 degrees out, running 93, traction control on (Hondata + vsa). All right before it snowed (yay).
    I remember one log file I had looked at was too short for my needs and I deleted it but remember seeing the acceleration times, and I kept it in my head thinking - cool. You know, started off slow as heck in third and just wanted to record that power take me out to paradise. I do remember the run and it was fast.
    Anyways, I’m watching this YouTube video of an R and he’s driving hard starting at 2500 in 2nd all the way through 3rd and to the middle of 4th.
    That’s when it hit me, holy sh$t. My car is really fast...
  7. SpsTech
    SpsTech @phoenix_fk8
    Jan 14, 2020
    Occupation:
    Honda Technician
    St.Augustine Florida
    Stephen
    2019 FK8
    is there any way data from a previous flash can corrupt a new flash and give slightly less power than before when your supposed to have more power?
  8. OP
    Hondata
    Hondata Hondata
    Nov 27, 2015
    689
    2,001
    Occupation:
    Engineers
    Torrance California
    93 Integra, 06 Si, 12 Si, 17 Si, 19 Si, 18 FK8, 18 Accord 2.0T
    When you reflash the ECU is includes a checksum of the ECU memory, so if the ECU memory does not have exactly what you intended it will go into recovery mode. So nope, not possible.
    SpsTech and jasonjm thanked this.
  9. AdamD19DFK8
    AdamD19DFK8 Senior Member
    Jul 11, 2019
    298
    128
    Maryland
    Adam
    2019 FK8 Type R, 2007 Civic Si sedan
    Lol I like watching people's pulls in 4th gear to determine if they've got more power or not. If their speedo refreshes by 2's or up to 4 at a time I can bet it's not. Mine usually refreshes by 5 between 80mph-110ish. Sometimes I get lucky and it increases by 6 at a time:lol:
    If I ever see it only increase by 4 I get mad thinking "what the hells wrong with my car". Fuel pump is always fine in 4th, 3rd gear it's really temperamental and I have to keep the torque targets much lower.
    I still don't understand how 4th can use much higher torque targets (like 535nm at the top) and 3rd gear I have to keep them around 475 at 5k-6k with only being able to use a hair over 500nm at the very top
  10. MstrSHAKE
    MstrSHAKE Senior Member
    Jul 7, 2019
    103
    54
    SFL
    Adrian
    '19 CW CTR
    can i run the hondata flaspro software on a laptop with windows 10 in S mode, or does it have to be home?
  11. Spunkster
    Spunkster Senior Member
    Mar 16, 2017
    58
    26
    17 CTR, 2x 98 ITR's, 88 Integra, 06 RSX Type S
    It probably will not work in S mode, as it can only use apps from the app store.
  12. kefi
    kefi oh shit waddup its dat boi
    Jan 8, 2020
    76
    101
    Occupation:
    Software Engineer
    Seminole County, Florida
    2018 Type R
    Apps for S-mode windows are compiled differently, so it's pretty unlikely. They could add support for it though without too much trouble.
  13. jasonjm
    Jul 29, 2018
    810
    387
    Pennsylvania
    Jason
    Type-R
    Get a hold of windows 10 install online and create a bootable USB stick that will run the install. Your Windows Home key should be embedded in the bios of S machines. Otherwise you can get a legit key online for super cheap.
    I use a S machine that I instead installed Windows 10 Pro on. Works great.
  14. MstrSHAKE
    Jul 7, 2019
    103
    54
    SFL
    Adrian
    '19 CW CTR
    #644 MstrSHAKE, Feb 19, 2020 at 9:33 PM
    Thanks for the replies. I was wondering because I haven’t gotten a hold of a laptop yet but was searching around and typically the lower budget laptops are running win10 in S mode. I’ll look for a win home laptop then! Thanks y’all.
  15. jasonjm
    Jul 29, 2018
    810
    387
    Pennsylvania
    Jason
    Type-R
    Just to be clear, I bought a windows S laptop. But installed windows 10 Pro on it. Everything works great.
