FK8 on E85?
  1. FlexRex
    FlexRex Senior Member
    May 13, 2019
    341
    166
    Arizona
    WRX and M5
    @OneSickFK8 If youre getting retard/knock due to not having 93oct or still getting timing pulls then you could add 1-2gal of e85 then fill the rest w 91/93 and see if it helps reduce knock.
    But thats not picking up power, rather allowing you to use all of it if experiencing retard/knock (due to octane).
  2. OneSickFK8
    OneSickFK8 Senior Member
    Oct 6, 2019
    308
    165
    South, FL
    Jae
    PMM FK8
    I use Shell 93. The car seems to only pull boost when it's hot outside. I was just wondering. So basically use it like a octane booster of sorts. Just 1-2 gallons to a full tank. Got it.
  3. FlexRex
    May 13, 2019
    341
    166
    Arizona
    WRX and M5
    Yes, start w 1 first then 2 if needed. It can help only to a certain point by slightly raising octane like you said.
    It wont help w charge temps of 130f+, this is just for when you’re at that threshold and slightly over it.
  4. Justotarula
    Justotarula New Member
    Jan 4, 2020
    Moreno Valley
    Justo
    Honda Civic Type R
    This article states the test vehicles had stock blocks. Does anyone know about headwork i.e. cams, valvetrain etc?
  5. FlexRex
    May 13, 2019
    341
    166
    Arizona
    WRX and M5
    Not necessary and all stock. They did however have a tune for e85. You cant just run e85 on your oem tune.
  6. Justotarula
    Jan 4, 2020
    Moreno Valley
    Justo
    Honda Civic Type R
    Yes, the fuel kit and e85 tune is what the article is aboutso clearly it had that. I ask because the stock numbers are 333 lbs-ft and 317 HP and the dyno sheet only states the flex fuel kit, intercooler and high flow cat.
    I guess I’m wondering if the intercooler and high flow cat put it up to those numbers or was there something else not mentioned. Only stating stock block and not complete stock motor with those upgrades leaves some room to wonder
  7. FlexRex
    May 13, 2019
    341
    166
    Arizona
    WRX and M5
    #22 FlexRex, Jan 15, 2020
    Umm.. ethanol is what gave it power friend. Thats all.
    My wrx picked up 100awhp going from 91oct tune to e50 tune.
  8. Night Fury
    Night Fury Senior Member
    Jun 13, 2017
    985
    683
    Chicago
    Black Type R
    Mentioned before, Might be cheaper options than fuel upgrade system. Such as a bigger turbo. Still, with a better fueling you still can produce”based on Dyno numbers” more TQ on a stock turbo than a bigger turbo with no fueling upgrade. Between the two: I would fueling first. With R&D needed for an upgraded fuel kit, it is a no brainer just buy the kit, unless another tuner shows up with something cheaper.
    For comparison: VW Golf R’s fuel kit is just $200 cheaper than ours(Flex kit not included), so it’s not that bad & you can forget about E30 or 40, just straight E85. You always gotta pay to play.
