Fk8 OEM exhaust on Fk7 question
_HatchED_
Eddie
South Carolina
2019 Hatchback Sport 6mt
So I've been running this exhaust on my hatch for a couple of weeks now and I couldn't be happier with it. My one issue with it is the small brace that has to be removed because of the front/small resonator. For those running this exhaust, what are you using to replace this mount?
Thanks
Shadowfighter
Idaho
2017 civic hatchback sport manual
You don't need that brace. The Fk7 is the only civic that has it.
I had a exhaust shop cut that small resonator out so that I could put the brace back on. But that wasn't the main reason I had it cut out. I was looking for more sound and I wanted to get rid of the 2 inch bottle neck at the start of the exhaust.
Honda Civic 10th gen Fk8 OEM exhaust on Fk7 question 20181222_005916
Honda Civic 10th gen Fk8 OEM exhaust on Fk7 question 20181222_010438
_HatchED_
_HatchED_
Eddie
South Carolina
How much louder is it with the small resonator out? Also, did the drone increase?
_HatchED_
_HatchED_
Eddie
South Carolina
Honestly it sounded the same to me. Maybe slightly louder. I didn't notice any additional drone.
I've been debating taking it out, but probably going to wait to see how much louder it is with a down pipe.
Ghosted
D
CA
Civic Hatch Sport
I just got the FK8 exhaust and people said this was a direct bolt on. Did I hear wrong? What customization do I need to do?
_HatchED_
_HatchED_
Eddie
South Carolina
Bolts up like stock. You just need to trim the bumper garnish so the tips can fit.
Ghosted
D
CA
Civic Hatch Sport
Thanks HatchED. Does the front pipe fit on too? Did you guys buy new exhaust gasket?
_HatchED_
_HatchED_
Eddie
South Carolina
Idk. I have a catless dp/fp combo I install in conjunction with the catback, and used the supplied gaskets.
Ghosted
D
CA
Civic Hatch Sport
Since you bought the aftermarket DP/FP, was it a 2.5 or 3". When you said you got rid of the 2" bottle neck, did you replace it with a 2.5 flange to connect it with you aftermarket FP?
Shadowfighter
Idaho
DP/FP are 3 inch. Yes it was replaced with a 2.5 flange.
Ghosted
D
CA
Civic Hatch Sport
I tried searching, but couldn't find a diffuser that would fit our sport rear bumper with the Type R exhaust. Anyone here can help? I remember seeing one before.
Shadowfighter
Idaho
So you don't want to run the stock diffuser? What year is your sport hatch? I don't think the new sport diffuser will fit the type r exhaust.
Ghosted
D
CA
Civic Hatch Sport
Want to see what options are out there. 2018 Sport. I'm not sure if the 2020 diffuser will fit.
Shadowfighter
Idaho
Ah I see. Sorry I don't know of any. I am pretty sure the 2020 sport diffuser will not work though.
