Speaker
- Jan 2, 2018
- 5
- 4
- Pennsylvania
- 2018 Honda Civic Type R
This is my first manual car, so I don't have much experience with this, but while driving when I push in the clutch, and move the knob from 1st to 2nd gear the car seems to fail to synchronize the gears and the RPM will just keep dropping until I let off the clutch, which will then spike the RPM back up as everything is forced to synchronize, resulting in a pretty jerky shift. But, if I hit around 18 mph or around 4000 RPM before shifting into 2nd gear it seems to synchronize and holds the RPM fine and results in a smooth shift.
Also, I don't normally skip gears when up shifting, but I have tried going from 4th to 6th a few times, and each time the same thing happens where it doesn't synchronize and the RPM will just keep dropping, and letting off the clutch spikes the RPM back up, resulting in another jerky shift.
Another weird thing is when downshifting from 4th to 2nd. The auto-rev matching always works flawlessly except when going from 4th to 2nd. There seems to be a pretty significant delay compared to any other downshift.
Lastly, when I do get to around 18 mph or so while in first gear, and completely let off the throttle I can hear some weird kind of whirring noise. Not sure how else to explain it.
Has anyone experienced any of these things? Is this normal or what?
