Vtak Groceries
Having the intake directly above the turbine like it is however, will greatly reduce the efficiency of the compressor versus if the compressor could draw air from ambient. This civic will heat soak alot, IMO. That intake pipe will be HOT after running the engine hard. End of the day not a deal breaker.... Just seems weird. Maybe they didnt have the space.I don't think CAI's on turbo cars generally do as much anyway. Once the air is compressed it heats up much more anyway. The temperature of the compressed air is about the same if the CAI only makes the intake air 20degF cooler... now if you can make it maybe 60 deg cooler then we're talking, but otherwise the true gains tend to be more from improved flow (at the cost of increased noise) more than the colder intake temps.
This is different in NA cars. In NA cars, the colder air isn't being heated by compression so it does do better to resist detonation. One problem - higher flowing intakes tend to have slightly more laminar flow which is NOT good for fuel evaporation- another reason a tuned car will use slightly more fuel.
I'm no expert by any means - I only took 1 class in Internal Combustion Engines and a good portion of that was spent calculating displacements and thermal efficiency in turbines or in closed systems, not necessarily how to get MAX POWER from our traditional 4 cycle engines.
