Finally, proper lowering springs specific to Si Coupe & Sedan - by Eibach
drewnik
JD
San Diego
2017 Civic Si Coupe
Is your camber off in the back? Did you get an alignment afterwards? Car looks good.
Yes, the camber is off now. I haven't gotten an alignment yet to see by how much. It doesn't look too bad to me but I will be getting a camber kit for sure.
JNOR
FL
00' EX H23A, 17' Si Sedan WOP
This may be a stupid question but how come only the rear is cambering after lowering? Along with that all I am seeing are rear camber kits mostly. :dunno:
bbrtuning
Beau
Los Angeles, CA
2001 BMW E46 M3, 2018 Civic Si, 1999 Eclipse GSX
All stock car suspensions are designed to gain rear camber faster than front camber. This makes the car more likely to understeer when cornering, which is safer and easier for novice drivers to "control". On top of that, most modern cars (including the Civic X) use an inferior/cheaper front suspension design called McPherson strut, which has essentially no camber gain during cornering. For performance, you typically want more front camber than rear camber, especially on a FWD or AWD car. So, often, someone looking to drive their car more aggressively will welcome the slight front camber increase that you get when lowering, but will want to eliminate the excessive rear camber that you also get when lowering the car by installing a rear camber kit.
elusiveaura
Tennessee
2020 CW CTR - 2020 Acura RDX A-Spec
Looks great. This the pro kit or the sportlines ? Did you do a camber kit?
Finally lowered it. It's about a one finger gap all around. The ride feels somewhere between normal and sport mode.
elusiveaura
Tennessee
Scarlett is running the sportlines. They’ve been out a while now I believe.
It's the PRO-KIT.....Sportline isn't available yet.
totopo
CA
'17 Civic Ex Hatch, 370z
which is silly because usually when you lower macpherson enough to see negative camber, your lower control arm is too horizontal and when you actually corner you can start seeing positive camber on the loaded tire which is very bad.
sometimestwice
South Carolina
2016 Civic EX sedan
jaydubz79
2017 Si
Does Eibach specifically state that the springs are designed to work with adjustable dampening system?
3925blue
Texas
2018 Honda Civic Si sedan
The spring doesn't have anything to do with the ADS. All that system does is turn a valve that makes the struts/shocks a bit stiffer. Slightly shorter/stiffer springs will not affect it. Extreme changes in ride height or spring rate will affect long-term life of the dampers just like any other car, but Eibach Pro-Kits have never been extreme.
