FINALLY bought a Ktuner ( i got some noob questions )
BL55D
Lance
Australia
2018 Honda Civic RS
im finally having fun :spaz::spaz: thankyou guyss!
All the ramp settings are safe. The only setting you need to avoid is disabling boost ramp. That's too rough on the CVT.
Getting back to this whole tune versus map thing. I'll try to explain it to help SilverArrow's/BL55D's confusion. A tune is what gets uploaded to the KTuner unit which then gets uploaded to the ECU.
Within a tune (if you have on the fly map capability) there are three different maps. Each map can have different boost and settings. These individual maps can then be switched with the cruise control buttons.
The confusion comes from the fact the KTuner software labels the three maps as "tune" 1-2-3. Those are actually maps 1-2-3.
Hope this helps.
BL55D
Lance
Australia
2018 Honda Civic RS
All the ramps settings are safe. The only setting you need to avoid is disabling boost ramp. That's too rough on the CVT.
Getting back to this whole tune versus map thing. I'll try to explain it to help SilverArrow's confusion. A tune is what gets uploaded to the KTuner unit which then gets uploaded to the ECU.
Hope this helps.
Someone told me i cant change the ramp cos apparently its too “hard” and might mess up my trans. Went from agressive II to improved I and it kinda lost a lil bit of fun. LOL
Thankyou gtman! Youve been a great help. Also, now that its all uploaded, can i take the ktuner off the obd port? Lol im unsure if i need to take it off or keep it there. Lol
Yes you can remove it.
Please read my topic about my KTuner experience. It will help you greatly. It's always better to have a good grasp on tuning before you play around with settings in my opinion.
SilverArrow
Italy
Honda Civic X 1.5 T. Sport
Hope this helps.
Thanks gtman, but i'm not confuse.
I understood but with my bad english it is not always easy to explain.
Bye
BL55D
Lance
Australia
2018 Honda Civic RS
Im running dual tune atm (eco on + off ) i havent really messed around with the tune just yet- but i was kinda scared to amp the ramp settings cos it was something i was not familiar with
Like I said, it's important to understand what those settings do and how they interact with each other. Ramp is for high throttle situations. The more aggressive the ramp the quicker you hit the boost target when you are pressing hard on the throttle. The factory setting gently ramps to the target.
BL55D
Lance
Australia
2018 Honda Civic RS
Youre right- ill be doing some research ( read your posts and visit ktuner website ) and learn about the basics :) so far- i am having so much fun lol even took the longest route to get home from work :3 thankyou!!
NSaneeee
Jordan
North Carolina
2019 Honda Civic Sport Sedan
I have a question I just uploaded base map for my 2.0, if I want to switch to throttle response 1 or 2 I just select the one I want then reflash same way correct?
BL55D
Lance
Australia
2018 Honda Civic RS
i would think so! dont take my word on it tho- im doing dual tune for now but i will be trying to do starters when i get home from work. i want to set up 3 maps that i can just swap on the fly lol
NSaneeee
Jordan
North Carolina
Well you got the si with all the options lol 2.0 only has one map :(
BL55D
Lance
Australia
2018 Honda Civic RS
I actually have the 1.5T CVT hatchback lol we sadly dont have si in australia :(
n0chance
US
Honda Civic Hatchback Sport
they are all safe
stage 2 is blocked or almost
the dual can be modified
start with stage 2, and enjoy, then try the dual in the various settings and enjoy
the only thing that doesn't appeal to me is to disable the rev hang
when you're tired, pay 79 dollars a tsp and enjoy with their melody, it's much more refined
in short ..... there is much to enjoy
advice, remember to use the low gears, 5 & 6 use them only for rest,
if you sink, remember that you are at least above 2500 rpm
and use premium fuel, don't be a louse, in Europe the premium petrol we pay you from 1.3 euros to 2 euros liter, liter not gallon, you're lucky
Hi,
I am also looking to tune for the first time and been reading a lot of threads. some questions:
If i use the starter 21 tune but don’t adjust any settings, is that the same as stage 2?
I read going full throttle from 0 is not good for long term durability and i’m not looking to do that at all. id like to avoid accidentally doing that but would like to reduce the lag (from what others post). do you need to adjust settings for that?
thanks!
SilverArrow
Italy
Hi,
thanks!
No, in others thread KTuner says that stage 2 is more aggressive of of starter 21.
If you enable early spool and follows settings:
- throttle responsiveness
- turbo spool
- turbo responsiveness
- boost target ramp rate
you reduce the lag......and you have a lot of fun!
The Starter 21 out of the box is less potent than the Stage 2 if you left all the settings at factory. The magic happens when you adjust the quick settings and enables.
For example, to reduce part throttle lag - enable early spool, and use improved spool, throttle and turbo response settings.
The ramp setting is for full throttle and hitting boost targets quicker.
The downside of making things too aggressive is that the tune will be snappy at part throttle but fizzle out a bit at high rpm.
