FINALLY bought a Ktuner ( i got some noob questions )
BL55D
Lance
Australia
2018 Honda Civic RS
Yes, you can save 5 tunes.
and switch tunes without laptop?! i heard you can only switch tunes on the fly with the v2- i was hoping i can with v1 + tunerview ;o would be awesome if i can tho
SilverArrow
Italy
Honda Civic X 1.5 T. Sport
You can load 5 tunes from the laptop to the tunerview.
Then, you can update a tune in your ECU directly from tunerview.
Honda Civic 10th gen FINALLY bought a Ktuner ( i got some noob questions ) IMG_20190826_182225339
You can also switch tunes on the fly, by cruise control, but i can't help you because i have initial support for my ktuner 1.2.
Gotch
Rob
2022 Si
As far as I know, you can’t switch tunes on the fly. Maps yes, but not tunes. Tunes have to be flashed. Just putting that out there.
SilverArrow
Italy
I have understood this:
- you can switch maps directly by tunerview
- you can switch tunes (3 inside map) on the fly by cruise control buttom.
Is it right?
On the fly map switching means you load a tune (containing 3 maps) and then you can switch between the individual maps with the cc buttons.
I generally don't use Tunerview but my understanding is you can upload a tune with it but you can't switch maps with it.
BL55D
Lance
Australia
2018 Honda Civic RS
did you switch maps using tunerview?
I don't believe you can. But even if you could, why would you? It would be much more distracting and clunky. Using the steering wheel CC buttons works really, really well.
BL55D
Lance
Australia
2018 Honda Civic RS
oh thats true tho- using the CC would be less of a distraction and easier access :doh:
SilverArrow
Italy
By turnerview you can load maps in your ECU that you have saved into tunerview from ktuner.
Honda Civic 10th gen FINALLY bought a Ktuner ( i got some noob questions ) Screenshot_20190922-083513~2
By cruise control buttom you can load tunes.
It is not the same.
SilverArrow
Italy
I bl55d, have you plugin your your ktuner?
Do you have starded to enjoy?;)
Linszter
TunerView Developer
Peter
Hungary
2003 Accord K24, 2005 Civic K20 VSA
It is not the same.
Actually you save the tune into your KTuner unit and you can initiate the Flash process with TunerView.
SilverArrow
Italy
And this?
"By cruise control buttom you can load tunes on the fly"
In the image attachment, by cruise control buttom i can switch tunes 1-2-3. Is it right?
Honda Civic 10th gen FINALLY bought a Ktuner ( i got some noob questions ) Screenshot_20190923-085507~2
BL55D
Lance
Australia
2018 Honda Civic RS
ktuner finally arrived :spaz: Yess i am, just wanna ask tho. Is it safe for me to run agressive ramp II? CVT
Linszter
TunerView Developer
Peter
Hungary
And this?
That's On the fly map switching with the cruise buttons. Those are two different things. You just switch to different maps within the "tune".
With TunerView you flash a different tune to the ECU.
