samt2497
Must be that then, I'll attempt to log it with OBD2 and Torque the next time.You do realize the turbo dash gauge on the non-Si is basically a toy for "entertainment purposes" mostly.
I think your car is just fine, also you should hold on a little bit before pushing the car, let it break in properly.Oh, can I plug turbo meter to see whether there is boost leak or not when I hit the throttle?
i would go back and tell him whats going on with your ride...and just in case ask him to try reflashed it back to normal....ask politely too@hfpdohc I have told him about this issue and he said he has taken my civic original data and will inject it back to the ecu. He shows me the picture of my ecu number, but later I found it was not mine. The number he gave me is civic 2019 ecu number (37805-5ag-uf10), whereas my civic 2020 ecu number is (37820-5ag-uf1).
Now I am confused, whether to come back to him and fight with him or to seek other help.
I wish somebody here can help
My Si feel less powerful now in regular drive mode than it did when it was new, but whenever I put it in Sport mode, it reminds me that I've probably just gotten used to it. Usually if there's a leak in the intake, the diagnostic would show a clear loss.Fellow friends, I need help.
My civic is running at 1000km, still fresh.
Since I brought this car from dealer, I feel the turbo boost at RPM 2500-3000, at low speed (30-50km/h), it feels lag and then sudden boost coming out, feels greats and I can feel the torque steer little bit.
But I don't know why, few days ago I feel quite different. When I push the throttle at RPM 2500-3000, it really smooth, like linear, I feel like low boost, until RPM 3500 above , then I can feel being pushed back to the seat.
No modification yet, just original BMC replacement filter. I put the oem air filter back, but still feels the same.
I bring to honda dealer, but the diagnostic tool not detect any error.
But I concern about something. It shows spark advance at below idle minimum number. It says 0.5, whereas the min idle number is 3.
And also the fuel injector shows above the max idle number. It says 4, whereas the max idle number is 3.
What do you guys think?
Leak turbo?
Or ecu error?
Or just my feeling?
Thank you anyone
You dont like more power?@Hollywoo0220 yepp this car civic 2020 makes me smile, because before I enter his garage, It will boost at 2500-3000 RPM, but now after he do reading my ecu, just reading (he said, because I don't ask him to tune my ecu), and now it feels so smooth like a girl. The turbo kicks hard now at 3500-4000, oh god
