Feel no difference between 19.5 and 23
  1. Yaminashi
    Yaminashi Member
    Jun 1, 2017
    Cincinnati, OH
    91 Integra DB1, 18 Civic Si
    I have the dual tune on my Si and it honestly doesn't feel any different putting it back and forth. Did a 0-60 in both modes and came to same times also have looked at the in car boost gauge and it peaks out at about 17 psi. I know the car still looks for the right parameters but I still feel like I should feel a difference between the two tunes.
    Papayank thanked this.
  2. Masked
    Masked Senior Member
    Jul 12, 2019
    50
    Quebec, Canada
    Jos
    2018 Honda Civic Si
    Peaks at 17psi in sport mode? Mmh check for boost leak, also do you have a datalog?
  3. gtman
    gtman Senior Member
    Oct 27, 2015
    5,138
    5,213
    Occupation:
    CivicX addict
    U S of A
    2017 Cosmic Blue Civic EX-L
    Don't go by your stock boost gauge. Hook up your KTuner and run a datalog as suggested above. No way your boost should peak at 17 psi on those tunes.
  4. OP
    Yaminashi
    Yaminashi Member
    Jun 1, 2017
    Cincinnati, OH
    I'll try and get tunerview up and running to see what it says my boost is at.
  5. Design
    Design Senior Member
    Sep 28, 2015
    3,004
    2,561
    Southern California
    09 MS3, 17 ABM Si Sedan
    Even the stock boost guage should show a significantly higher PSI readout above 4K RPMs... at least in 3rd gear and above.
    Question: Did you configure the map switching options in the desktop software?
  6. OP
    Yaminashi
    Yaminashi Member
    Jun 1, 2017
    Cincinnati, OH
    The only thing I did was check the options for turbo responsiveness.
  7. Design
    Sep 28, 2015
    3,004
    2,561
    Southern California
    I suggest manually setting your normal/sport boost targets for all three maps - even if each map would have the same parameters.
  8. OP
    Yaminashi
    Yaminashi Member
    Jun 1, 2017
    Cincinnati, OH
    Reflashed the car today with the same tune and selected the boost targets for normal and sport, still getting peak psi at 17.5 for both tunes from the car and on tunerview.
  9. gtman
    gtman Senior Member
    Oct 27, 2015
    5,138
    5,213
    Occupation:
    CivicX addict
    U S of A
    Boost leak somewhere it would seem.
    Run a full datalog and do some WOT pulls and upload it here.
  10. Design
    Sep 28, 2015
    3,004
    2,561
    Southern California
    Did you update your software parameters as suggested? Or do they still say custom level?
  11. OP
    Yaminashi
    Yaminashi Member
    Jun 1, 2017
    Cincinnati, OH
    I updated them as suggested. I'm going to run two separate datalog files tomorrow, one for the 19.5 and the other for 23.
  12. gtman
    gtman Senior Member
    Oct 27, 2015
    5,138
    5,213
    Occupation:
    CivicX addict
    U S of A
    No need for two datalogs. Just do half the drive at 19.5 and the other at 23.
    Design thanked this.
  13. OP
    Yaminashi
    Yaminashi Member
    Jun 1, 2017
    Cincinnati, OH
    First half is in normal, second half is in sport.
  14. KTuner
    KTuner Senior Member
    Jul 10, 2017
    1,838
    2,374
    Occupation:
    Engineer
    Chandler, Arizona
    J.R.
    2017 Si
    You're not on a tune. You likely uploaded to the unit instead of flashing or failed a flash and recovered back to factory.
    Design, Yaminashi, Masked and 1 other person thanked this.
  15. OP
    Yaminashi
    Yaminashi Member
    Jun 1, 2017
    Cincinnati, OH
    Thanks, glad I'm pretty dumb. I'll try it out tonight.
