Factory wheel size, offset, and weights
AndreyL
Bethesda
2017 Civic Si
I’m on mobile so searching is kind of a pain and I figured I’d ask here:
What’s the most aggressive offset possible on the stock Si? I’m wondering if a concave look is even possible on this car? The +50 offset makes any kid of wheel look super cheap imo, so if I can’t get any concavity going I’m probably just gonna stick with stock wheels. I’m not talking about a crazy 4” lip or anything like that, just a decently concave look.
MavicTB
Terry
Dallas
18 Civic Si Sedan Aegean Blue
Check this thread out to give you some idea of what people are running for lower offset setups.
https://www.civicx.com/threads/aggressive-wheel-fitment-thread.26817/
KYRGYZ
Bay Area
16 Civic LX, 18 Model X 100D
just another confirmation, if you want to go light weight, go with steelies :D :D :D :D
Honda Civic 10th gen Factory wheel size, offset, and weights IMG_5055
ikbenben
Belgium spec
Belgium, Europe
'17 Civic 1.5T Sport Plus HB
You think...my 19" are lighter (40.5lbs) :p
GixxerMKD
Baze
Macedonia
Honda Civic 1.5 Hatchback Sport 2018
2017-2018 Civic Hatchback EU
Wheels : 17x8 ET50
Tyres : Michelin Primacy 3 - 235/45/17
Total weight : 47.4lbs (21.5kg)
Do you know whats the bolts span, 5x120 or?
ikbenben
Belgium spec
Belgium, Europe
Fredwithanf
Fred
Denver, CO
18 Si Sedan
Anyone know if I could run a set of rims of a Subaru WRX? Bolt pattern looks ok, not sure about the centerbore, and I'm not sure if the +.05mm offset would make a noticeable difference, or make it so they conflict with the calipers.
Here are the specs:
Bolt pattern: 5x114.3
Centerbore: 56.1mm
Wheel size: 17 x 8"
Offset: +55mm
MavicTB
Terry
Dallas
Here are the specs:
Centerbore: 56.1mm
Wheel size: 17 x 8"
Offset: +55mm
No it will not fit. Centerbore is too small. Our hub is 64.1
SCOPESYS
Geoff
MD
Here are the specs:
Centerbore: 56.1mm
Wheel size: 17 x 8"
Offset: +55mm
What +.05mm offset ??
SCOPESYS
Geoff
MD
I was just referring to the added .05mm offset. Stock Si=.50mm, stock WRX=.55mm
Think now SMALL 0.05mm is !!! Thinner than a "thin" Human Hair
Europeans consider hair with a diameter of 0.04 to 0.06 mm as thin
You have the decimal point in the wrong place ?
Si = 50 mm
Wheel Configuration Reference
Vehicle Make & Model Year Range Wheel Offset Range
Honda Civic Si
2006 to 2015 +38mm to +48mm
Honda Civic All Except Si / Type R 2016 to 2018 +38mm to +48mm
Honda Civic Si 2017 to 2018 +42mm to +55mm
Honda Civic
Type R 2017 to 2018 +42mm to +60mm
Fredwithanf
Fred
Denver, CO
18 Si Sedan
Si = 50 mm
Honda Civic Si
Honda Civic
Yes. Decimal point in wrong place, but kind of a moot point since the centerbore is a no-go. Thanks.
jeffreyj
Jeffrey
Ontario
2016 Civic LX with Honda Sensing
Anyone know if 16x6.5" rims with a +55mm offset would fit my car ('16 LX)? Planning on putting the stock tires onto these rims, any issues with a 215/55/R16 tire on a 6.5" wide rim?
bubbaleenc
Owning the country roads.
North Carolina
'16 EX-T Sedan '01 4Runner '18 Suburban
Most 215/55R16's will fit rims from 6" wide to 7.5" wide. However, it will depend on the tire. Every tire model will tolerate a slightly different wheel width range. For example, the Goodyear Assurance ComforTread and Cooper CS5 Ultra Touring in the 215/50R17 and 215/55R16 are 7" wide tires good for 6" to 7.5" rim width.
