Factory wheel size, offset, and weights
VarmintCong
Taiwan
2023 Ford Focus ST Line X (sold 2020 Si sedan)
$3,000 for the whole set in Canada. Then there's 5-15% tax depending on the province you live in. No shipping from the US, so College Hills Honda and all that are out of the question.
Sounds like a road trip is in order.
mno86
Milwaukee, WI
2016 Honda Civic Touring
2016 Touring wheels:
17x7"
+45mm offset
47.2 lbs (with tires)
If the Touring wheels have a 45mm offset, and the winter tire/rim package I'm looking at has either a 38mm or 48mm offset...what are the implications? Is one better than the other or are both less than ideal? Why?
ronmcdon
Beverly Hills, CA
19 FiestaST, 19 Si, Camaro Z1LE, EvoX, 98 240sx
I looked up the tire weight, it was 24 pounds.
So the wheel is 27.8 lbs, seems kind of high.
Looking at getting the sport touring hatch when it comes out. Def one of the first thing I will do is replace the stock wheels with a set of 16lb, 17x8 enkei RPF1's. Cant hurt to lose 40lbs of unspring weight
YTouy
Colorado
Civic Touring
Anyone know how much pressure is needed in stock Touring wheels and tires? My LX door jam says 32psi front and rear. Curious because I swapped out my steelies for some touring wheels and tires. I know they're most likely different. Or can someone with a touring please check out what it says on your doorjam?
Honda Civic 10th gen Factory wheel size, offset, and weights FullSizeRender(25)
This is from the door jamb of my Civic Touring sedan.
Tonysil
Western Mass
Does anyone know what the part number for the 2016 Touring Sedan wheels are? I need to replace one and it seems like prices online are much better than the msrp but I keep finding two different part numbers, possibly different manufacturers? I'm hoping that somebody either knows the difference or can tell me how to find it.
skstyle
Toronto, Canada
2016 Civic Coupe EX-T
42700-TBA-A81 - Aluminum Wheel Disk (17 x 7J) (Kosei)
42700-TBA-A82 - Aluminum Wheel Disk (17 x 7J) (Enkei)
2016 models are using 42700-TBA-A82.
2017 models are using 42700-TBA-A81.
Tonysil
Western Mass
Thank you, so I'd just like to confirm that the 2016 is actually the higher part number?
skstyle
Toronto, Canada
Yeah. 2016 models are using 42700-TBA-A82 manufactured from ENKEI.
SHIFTY
Saskatchewan Canada
2017 Civic ex-t coupe 6-spd
So just picked up my ex-t coupe... love it! I've read alot of reviews and people were not fans of the stock firestone tires that come with it. Mine has "Continental 215/50 r17 91H", anyone know if they are any good or are comparable with the firestones? May keep them to spring and then buy summer tires depending on how good they are.
TruthVandetta
Auburn, WA
can anybody help me out with offset. So im currently looking at Enkei Draco Performance wheels 18x8 and 5x114.3 currently the offset is +35 so i was wondering if this wouldn't be a problem... i currently have 2017 accord sport 19" wheels and it rubs it i turn the steering wheel all the way.
