ToofHurts
- Apr 5, 2019
- 76
- 495
- 364
- South Florida
- '19 CW CTR
Excellent write up! Very much appreciated.
If you have the time, would you consider making a video so we can get an idea of the sound? There is only "jonnys honda" that has a sound clip up on YouTube as far as I can tell. I'd love another demo.
No cutting needed , installed 2 and didn't need to cut the second intake....
don't remember any gaps...will reinstall and update post, but definitely didn't noticed it. I remember having to notch my lower scoop to have it fully seated on the support, so no springing back up. if not fully seating with any residual "spring" action pushing up, this gap may appear.For those that have the Eventuri, do any of you have these gaps in the airbox rubber seal?
Wondering if I didn’t get the install 100% correct and the gap is because the airbox is not fully seated.
Please lmk
Thanks
will do...just got back from yosemite ... do it tonight or tomorrow.Yes please check if gap exists when yours is reinstalled. Received a PM from a fellow Eventuri owner that just installed his that the gap is there for him also.
Tempted to take mine out and attempt to reinstall again to see if gap can be eliminated.
just wrapped up the install...no gap...at least not what you have...note the snorkel bracket fits completely flush to the factory bracket...hope this helps
I might be wrong, but the only part that would lift the entire box up would be the snorkel, as the bottom of the box sits on the top of the snorkel, so if the position of the top of snorkel is high, then the final position of the air box will also be high. Please let us know what you find...Thank you for this. Another member pm’d they had the same gap. Had a feeling there might be some adjustment that needs to be made...
Will pull the airbox back out when it’s time to clean the air filter (every 3k miles per the Eventuri instructions) and see if can get the fit right.
I gave it some more though, and realize that if I didn't notch the scoop, and try to move/force those 2-hydrolic line away from frame rail and fit the scoop in. The scoop will now be under compressive loading trying to "close" up the scoop opening, as those 2 hydraulic lines are really stiff, as they are under pressure. Now, this is probably ok under static conditions, but when the car is moving and going over bumps (dynamic conditions), which may exert additional compression force, then the scoop may crack / break at that point.Are you referring to getting the side scoop into position?
Instructions said the hoses would push around...I tried and had no luck at all. In fact, the scoop I received was used and must have been a return because it was marked up badly. You could tell the previous owner wasn’t all that smart and tried to force it in. I’m guessing he wasn’t successful. Total BS.
I regret not taking a picture...but recall loosening some holding brackets or hose supports, in order to get movement so the scoop could fit. Then re-tightened everything. (I hope )
My airbox fitment has a tiny gap, as shown in previous photos. When it’s time to clean the filte, i’ll probably pull the airbox see if can adjust get a better fit. I’ll take a photo then.
UFOCTR notched his sidescoop. I didn’t go that route, but his fit looks better than mine.
